Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 31
  1. #21
    ROG Guru: Green Belt Array KPRage PC Specs
    KPRage PC Specs
    MotherboardMaximus V Gene
    Processor3570k
    Memory (part number)Vengance 1866 8Gb Ram
    Graphics Card #1Zotac GTX 1070 Mini
    Graphics Card #2ASUS R9 280 DC2
    Graphics Card #3Radeon 5850 HD
    MonitorASUS VZ27AQ
    Storage #1Samsun EVO 850 Pro
    Storage #23 1TB HDDs
    CPU CoolerH80
    CaseMerc Alpha
    Power SupplyTX 650 80 plus Gold
    OS Win 7/ Win 8.1/ Win 10
    KPRage's Avatar
    Aug 2012
    26
    572
    Well dude.. Now that I did the basic frame in cardboard, I don't think the slide of PSU is necessary for now! The case is now: 20 inches in depth.. This should be enough to slide the mobo a bit and get into the bottom for any work..
    Also, since all panels are removable, there will be easy access to all the components..
    Though the link you have posted is helpful in the next case am planning..
    May need to get this case design into SketchUp dude.. Will need your help while doing that..
    Cheers,
    KP
    CPU: Intel i5 3570k OC'd to 4.6GHz @1.170V; Mobo: MVG; GPU: Zotac 1070 mini OC'd to +210MHz/+205MHz; Memory: 8GB (2X4GB dual channel) Corsair Vengeance 1333Mhz 9-10-9-T2; SSD: Samsung 840 pro; HDD: 1TB WD Green 6Gbps; PSU: Corsair GS 600w; Case: Bitfenix Merc Alpha:Hybrid Octane in progress; Cooler: Corsair H80 closed loop cooling @ high profile;
    Pre & Post Build Guide
    A lot of epic FAIL videos are made before one epic WIN video is made
  2. #22
    ROG Guru: Yellow Belt Array Pratham's Avatar
    Oct 2012
    21
    163
    Yeah...you can ask for help anytime...if you want it to be drafted I can do that from pencil sketch & dimensions also...
    Upload your cardboard model if it's finished..
  3. #23
    KPRage PC Specs
    Processor3570k
    MonitorASUS VZ27AQ
    CPU CoolerH80
    CaseMerc Alpha
    KPRage's Avatar
    Aug 2012
    26
    572
    A small update with some of the components included.. This is still a bare bone/ skeleton model.. Here is the updated plan:
    The top panel will be made of that plexiglass thingie.. The bottom panel will be made of standard aluminum.. A nice ROG theme for the outside of the case.. White on the inside..
    The side panels and, the latching system are still pending..
    Top view:
    Bottom:
    Front:
    Back:
    Left:
    Right:
    ISO:
  4. #24
    imMortal Kombatant Array Myk SilentShadow PC Specs
    MotherboardASUS Rampage IV Formula
    ProcessorIntel i7 3930K
    Memory (part number)8GB Corsair XMS3 1600
    Graphics Card #1ASUS Radeon 7970 3GD5
    Sound CardROG Xonar Phoebus
    MonitorSamsung SyncMaster SA300
    Storage #1Corsair Neutron 128GB
    Storage #2Seagate 2TB
    CPU CoolerCorsair A50 Pro Air Cooler
    CaseBitFenix Merc Alpha
    Power SupplyThermaltake Litepower 700W
    Keyboard Alienware TactX Keyboard
    Mouse Tesoro Gandiva H1L
    OS Win7 Ultimate x64
    Myk SilentShadow's Avatar
    Jan 2012
    266
    5,241
    You have chosen a really unique design there KP, I am going to say that i'm really looking forward to seeing this beauty built physically
  5. #25
    KPRage PC Specs
    Processor3570k
    MonitorASUS VZ27AQ
    CPU CoolerH80
    CaseMerc Alpha
    KPRage's Avatar
    Aug 2012
    26
    572
    He he.. Thanks mate.. That is the Challenge now! Since I don't have the tools, am looking at other options to get it built/etc..
    Cheers,
    KP
  6. #26
    ROG Enthusiast Array
    Jul 2013
    72
    Nice renders, Looking forward to seeing this built
  7. #27
    KPRage PC Specs
    Processor3570k
    MonitorASUS VZ27AQ
    CPU CoolerH80
    CaseMerc Alpha
    KPRage's Avatar
    Aug 2012
    26
    572
    A small update with some important parts included.. A big update coming up in a while.. Special thanks to Pratham for that..
ID:	23676Click image for larger version.
ID:	23677Click image for larger version.
ID:	23678Click image for larger version.
ID:	23679Click image for larger version.
    Cheers,
    KP
  8. #28
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    in what way will you have access to all the parts inside?
    are you going with 1 or 2 loops?
    what are you gona cool? ( havent read first page so )
  9. #29
    KPRage PC Specs
    Processor3570k
    MonitorASUS VZ27AQ
    CPU CoolerH80
    CaseMerc Alpha
    KPRage's Avatar
    Aug 2012
    26
    572
    Time for the eye candy.. Special thanks to Pratham for the awesome art work..
    Oh and, before I forget, this includes three different versions of it.. Few more coming up.. We will have a poll on which to choose once everything is in place..
    Hope you guys like it..
    Cheers,
    KP
  10. #30
    KPRage PC Specs
    Processor3570k
    MonitorASUS VZ27AQ
    CPU CoolerH80
    CaseMerc Alpha
    KPRage's Avatar
    Aug 2012
    26
    572
    Quote Originally Posted by kkn View Post
    kkn, its designed in such a way that, you can add 4 pumps and more.. The rads can be placed either on the front or on the back or on the side slants..
    Each panel is removable except for the bottom most tray.. The mother board tray and the bottom slanted trays will slide out.. The top trays will be removable to convert it into a benching case..
    You can cool all the components easily with this set up.. It has provisions for huge rads and fans too.. Depending upon how you will use your case as the positioning of each components will change accordingly..
    For e.g: If you want to use it as a normal case but you are the type who removes it occasionally (like me!), you can use it as a bench-cum-normal case.. To do this, put the rads, pumps and reservoir in the front or back or on the bottom slant.. This will make sure that when you do open the top portion (the top right slant panel, top most panel, left slant panel and, left side panel are all removable using a latching system).. The rest are slide to use..
    If you want to use it as a normal bench case ONLY, then you can remove the top panel off completely..
    If you want to use it as a 24/7 system but you won't fiddle much with it then you can add the rads, pumps and, reservoirs on the top slant panels too..
    Hope it clears things up..
    Cheers,
    KP
Tags for this Thread
