Using offset and manual?
Retired
Not applicable
I run my cpu at 1.06v on manual but when I try to enable offset so that the cpu will run at less volts when idle I cannot adjust the volts as they reset at 1,2v.
Is there anyway to run manual at 1.06v and also enable the cpu to idle at .08 ?
Thanks.
Raja
If 1.20V is base you will need to set a negative offset value and reduce the voltage down to where it needs to be. No way to program the deltas in Offset mode exactly.
-Raja
Praz
That will be one heck of a CPU if it can run at 0.080V at idle without crashing.
LOL!! that would be THE best sandy bridge ever...
I7-10700K @5.0Ghz
Asus Maximus Formula XII
32Gb Gskill Royal-Z @3600Mhz
Asus Strix RTX3090
Corsair HX850i
