Results 1 to 8 of 8
    New ROGer Array
    Jul 2013
    4
    Rampage 4 extreme raid problem
    When I get to the screen that says press ctrl-I I press that but it doesn't take me to the screen where I can start a raid array can any give me a solution?
    ROG Guru: White Belt Array neyuru's Avatar
    Sep 2012
    25
    91
    Are you using an USB based keyboard? If so you may try to enable support for USB detection at POST (you can enable this on USB configuration on the advanced tab of you BIOS and/or on the Boot tab under "fast boot" try to enable usb detection if available). If this doesnt resolve you issue you can try a PS/2 keyboard (for the sole purpose of ctrl-i'ing the raid controller)
    Dec 2011
    354
    25,742
    Is your Keyboard active? In other words how do you know your keyboard is being picked up?
    New ROGer Array
    Jul 2013
    4
    Quote Originally Posted by neyuru View Post
    can I use a usb to ps2 adapter?
    Sep 2012
    25
    91
    Quote Originally Posted by piplupgao View Post
    you might... report back if this resolves your issue
    New ROGer Array
    Jul 2013
    4
    nothing worked
    and yes my bios is updated
  7. #7
    Sep 2012
    25
    91
    You might try to connect the keyboard to another pc/laptop to see if it works (of interest the I and Ctrl keys, if it works, place the keyboard on another usb port to see if the one you are using is defective (Iwould recommendo using the ports on the back panel of the motherboard, not with any usb hubs)
  8. #8
    New ROGer Array
    Jul 2013
    4
    problem solved my keyboard had a broken "i" button
Tags for this Thread
