cstkl1 -
Thanks for the tip on 1.15v/1.20v.
Yesterday I had liniput_xeon64 using the configuration you suggestion on the other forum. I believe that was for 16GB ram. I was wondering why it was taking hours.
Anyways 1.15v crashed using the old settings. I ran Memtest86 for 50 minutes and it said it passed 1 time. Figured the ram was stable on the default settings.
Took your input from todays post:
Changed from Optimal Settings:
CPU Spread Spectrum: from Auto to
DisableSVID Control: Changed: from Auto to
DisableInitial CPU Input Voltage: from Auto to
1.7v Eventual CPU Input Voltage: Auto to
1.65vDigi+ Power Control - CPU Load-line Calibration: Auto to
Level 8CPU Power Phase Control: Auto to
ExtremeCPU Power Thermal Control: 130 to
140DRAM Current Capability: 100% to
130%I was a bit confused on the PLL Termination Setting since I have three options:
BCLK Tuning - Initial PLL Termination Voltage:
Eventual PLL Termination Voltage:
I changed all three from Auto to
1.0v Anyways,
1.15v was not stable. I adjusted to
1.20v and passed the test:
Intel(R) Optimized LINPACK Benchmark data
Current date/time: Wed Jul 24 09:34:01 2013
CPU frequency: 4.205 GHz
Number of CPUs: -1
Number of cores: 1
Number of threads: 4
Parameters are set to:
Number of tests: 1
Number of equations to solve (problem size) : 20000
Leading dimension of array : 20000
Number of trials to run : 5
Data alignment value (in Kbytes) : 4
Maximum memory requested that can be used=3200404096, at the size=20000
=================== Timing linear equation system solver ===================
Size LDA Align. Time(s) GFlops Residual Residual(norm) Check
20000 20000 4 25.628 208.1387 3.504283e-010 3.102058e-002 pass
20000 20000 4 25.559 208.6957 3.504283e-010 3.102058e-002 pass
20000 20000 4 25.584 208.4971 3.504283e-010 3.102058e-002 pass
20000 20000 4 25.551 208.7610 3.504283e-010 3.102058e-002 pass
20000 20000 4 25.534 208.9044 3.504283e-010 3.102058e-002 pass
Performance Summary (GFlops)
Size LDA Align. Average Maximal
20000 20000 4 208.5994 208.9044
Residual checks PASSED
End of tests
Here are the screen shots of the memory you've requested. I have not set the device to XMP mode and everything is in regards to the memory.
