07-26-2013 02:40 AM - last edited on 03-06-2024 08:22 PM by ROGBot
07-26-2013 08:46 AM
07-26-2013 09:03 AM
Clintlgm wrote:
Yes this has been going on since they produced the G75VW your Audio Card is different on the VX but the problems is the same and the fix is also the same check out this and this for he best solutions, just adapt it to your Audio Card The problems is exactly the same.
07-26-2013 10:46 AM
07-26-2013 08:26 PM
Clintlgm wrote:
Well if you turn off the subwoofer completely, do you still not have any sound coming out of the left speaker. Generally speaking this problems is that you can't hear the left speaker because the subwoofer is not a subwoofer and plays the same sounds that your left speaker does just louder. With the subwoofer turned off and you still don't have any sound from the left speaker you may have a bad speaker or bad connection. I had that on my G75 for the right speaker which was fixed on the 2nd RMA. Other than adjusting the software for the sound system there is nothing you can do about this with out voiding your warranty. Have you contacted Tech support? If this is a new unit you may be with in your return period for refund or replacement with your Vendor.
parasurfer1979 wrote:
I had this same issue. I posted a thread about this because most threads i read owners were having issues with there right speaker not working. I finally just reset the system back to default. The right speaker works but its a tad quieter than the right. I think it's supposed to be this way due to the fact that the sub is on the left side. For now i wont touch the audio drivers until a newer update comes out.
07-26-2013 01:22 PM
07-26-2013 02:31 PM
07-28-2013 05:10 AM
