Results 1 to 7 of 7
    Macx
    Guest
    Asus Maximus IV Extreme-Z and 2600k need OC HELP!
    Just purchased one of these boards, looking for alittle help
    can someone give me a template for 4.8-5.0ghz
    i'm watercooled, its not a great setup but it handled my 4.4ghz OC on my 920 perfectly
    any help would be highly appreciated.
    also Ram is Corsair Vengeance 1600 C8 2x4GB=8GB kit.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    309
    7,660
    Are you looking for a pre-defined template or a tutorial? Raja has written a tut for OC'ing which you might want to review.
    http://www.asusrog.com/forums/showth...e-Overclocking
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Black Belt Array Area 66's Avatar
    Jun 2011
    49
    2,276
    if your 2600k come from Costa Rica don't expect too much .
    Macx
    Guest
    Was hoping to find someone with a template to get me started, and how do i know if i got a good batch, whats the good stepping or stepping code etc, batch numbers
    Macx
    Guest
    just checked my 2600k is Made in Malaysia and batch number L104A418
    ROG Guru: Yellow Belt Array 69_Goat's Avatar
    Jul 2010
    145
    Quote Originally Posted by MarkedOne View Post
    This is crap.
    Costa Rica is just an assembly plant. It has absolutely nothing to do with the quality of the silicon.
    If I can find the post that explained that I will link it here.
    i7-980X | EVGA 762 Classified | 6GB Dom GT 2000C7 | GTX580 SLI
    i7-2600K | Asus MIVE-Z68 | 4GB Dom GT 2000C8 | GTX580 Martix
  7. #7
    Macx
    Guest
    so far stable at 4.8ghz at 1.424 probably gonna try pushing the multi til its not stable and increase voltage til its stable again, hopefully i can get 5ghz and call it quits
Similar Threads
  1. ASUS Maximus 4 Extreme Review
    By Kipper in forum Other Series Motherboards
    Last Post: 12-06-2011, 06:05 PM
  2. Another 5.9Ghz // SB 2600K with ASUS MAXIMUS IV XTREME
    By Hazzan in forum Overclocking & Tweaking
    Last Post: 08-12-2011, 02:08 AM
  3. i7 2600k w/ maximus iv extreme - multiplier problem
    By max11b in forum Other Series Motherboards
    Last Post: 07-28-2011, 10:32 AM
  4. Need help getting a stable 2600k overclock Maximus iv extreme
    By Dennisphere in forum Other Series Motherboards
    Last Post: 06-27-2011, 06:46 AM
