08-07-2013 10:09 AM - last edited on 03-06-2024 08:11 PM by ROGBot
08-08-2013 12:34 PM
goodwill295 wrote:
On a side note, upon opening my laptop i found that the VGA is for a G73JH series laptop and that the shell itself says it is a G73SW-A1 laptop...
08-09-2013 10:42 AM
cl-Albert wrote:
Glad to hear your motherboard replacement went successfully.
Not sure how you are checking the VGA card model, but the G73JH is using the ATI Mobility™ Radeon® HD 5870 while the G73SW has the NVIDIA® GeForce® GTX 460M, so if you just check your display adapter in Windows this should help you tell the difference between the 2 models despite whatever is printed on the circuit boards.
Hope this helps!
08-09-2013 12:40 PM
