I don't like looking at a pack of ram on my desk, would rather it be mounted, so can someone give me some known working parameters to make the following specs work?
CHV Formula 0506 Bios
1100T stock clock
Gskill Sniper 1600Mhz 4x4gb
HD6770
The CPU is cooled by a coolermaster V6GT and I have an antec CP-850 power supply with. Both the 8 pin and 4 pin EATX plugs on the board are jacked in, I haven't supplied power to the molex yet. So I have the power and cooling that I can handle a bit of OC if necessary.
I have tried Raja's ram setup guide but was still very unstable with all 4 sticks in, using just 2 sticks of the memory right now with moderate stability, mind you I haven't run any benchmarks or stability tests yet and haven't played anything but AIX BF2 on it so far. I plan to switch to an 8 core when the second generation is released, but if I can't get stability now, it will just end up being worse with the hungrier chip later on.
I think it can be narrowed down to just ram settings, all 4 sticks post perfectly, even when all mounted together, no DRAM led, no errors of any kind. Just incredibly unstable, resetting even when idling at desktop. When I had all 4 sticks mounted and opened CPU-Z, I got a memory voltage warning.
I am by no means an expert here, I bought parts based on advertised specs, thinking it should just work out of the box. I don't know anything about playing with voltage, or setting up ram whatsoever and I'm kind of afraid of burning money by cooking parts. So that is why I am asking for help.
Crosshair V Formula 990FX 0506 Bios - Phenom II X6 1100T - Gskill Sniper 1600MHz (4x4GB) - Saphire Radeon 6770 - OCZ Agility 3 60GB - WD Black 1TB - Cooler Master V6GT - Antec Dark Fleet 85 - Antec CP-850 - Windows 7 Ultimate 64
