Results 1 to 4 of 4
    ROG Member Array
    Jul 2013
    24
    G46vw Restore UEFI Firmware?
    Hey guys I installed windows 7 on this machine a few months back and now I am in the process of making a hackintosh. When I installed Windows 7 I lost my EFI partition. Is there a way to restore UEFI firmware? I created a GPT harddisk but I need UEFI in order to install windows 7 on a GPT hard disk. Thanks!
    Asus G46vw
    Intel® Core™ i5 3210M Processor
    GTX 660m 2GB DDR5
    8GB DDR3 1600 MHz SDRAM,
    750 GB 5400 HDD
    Windows 7 Ultimate db Ubuntu 13.04
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,123
    Yes you will need to create a UEFI USB install chip and maybe create a boot64 file. Check out these guides and upgrade notes
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Member Array
    Jul 2013
    24
    Quote Originally Posted by Clintlgm View Post
    So I can use this to create my UEFI Flash drive right? http://www.eightforums.com/tutorials...e-windows.html
    Asus G46vw
    GTX 660m 2GB DDR5
    750 GB 5400 HDD
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,123
    Yes rufus will set you up. I haven't used it, just created it myself. But other here have had great luck with it. Then you will be able to install to your GPT disk.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
