[WIP] Snef's Red Poseidon
upsnef
Hi
another project Build
Snef **Red Poseidon**
but this will be a little bit longer project, heuu in think :blahblah:
Parts list
Hardware
Cpu: Intel I7 3770k: *Received*
Motherboard: Asus Maximus V Extreme: *Received*
Mem: 16 Gb (4x4)Corsair Dominator GT 2133: *Received*
GPU: 2 x HD7970 reference: *Received*
Case: LD PC-V4 TestBench: *Received*
PSU: Silverstone ST1500: *Received*
SSD: OCZ vertex 4 256Gb: *Received*
Hdd: 3 x WD 500Gb Black 7200trm 2.5” drive in raid 0: *Received*
Cooling
Fan: 12 x Corsair SP120 hp white: *Received*
Fan Controller: Lamptron touch: Need To Order
CPU Block: EK Supremacy (CSQ) Plexi Nickel (polish): *Received*
Ram Block: EK Ram CSP plexi nickel (polish): *Received*
GPU: 2 x EK-FC7970 CSQ Plexi Nickel (polish): *Received*
GPU: EK-FC7970 Backplate white: *Received*
Rad: 2 x XSPC EX360 multiport: *Received*
Reservoir: EK-Multioption X3 RES 400 with white top and bottom: *Received*
Pump: D5 Vario: *Received*
Pump top: EK-D5 X-TOP CSQ - WHITE Acetal: *Received*
Tubing: Primochill Advanced LRT Clear 3/8” – 5/8”: *Received*
Fittings: Bitspower compression fitting, angle and spacer all white, Koolance QDC (silver or black not sure now): Need To Order
Coolant: EK Coolant Blood Red: *Received*
Thermal paste: MX-4 and Gelid (EK): *Received*
Mod
Sleeving: Darkside White and Red 2mm, 4mm and 10mm Sleeving *2mm and 4mm Received* Need To Order 10mm
Connector: all white connector: *Received*
White, Black and Red paint: *Received*
Full White, Red and Black Sticker: *Received*
Red and black screw, and thumb screw: *Received*
And more, inspiration will come in the building process
anyway for now its only a Teaser
Nahhhhhh, its not just a teaser, I have more pics :ass:
i'm still in panning mode and need to chose coolant/sleeving mode
my sleeving will be white with red accent
little work on fan
I want to know the result of little idea I have in my head with the fan and I think the results is really great
Corsair need to release these fan in white
what do you think?
start painting
first phase backplate, little plate on waterblock and power supply
sorry for the pics but I will not bring my camera in my paint booth lolllll :lawl:
second phase will be , motherboard block, icy dock, cpu block with plastidip
and third and final phase will be , Aquaeroe 5 (plasti dip), reservoir support, fan screw and other little thing with primer and real paint
Update:
some items are now painted
First Fannblade case Feet:
WOW! they are nice
and these feet is a must on all build/mods
I painted my CPU waterblock
and a way better than black for my Red Poseidon, imagine with red coolant, again WOW
and finally, GPU backplate, they will be install wirh red screw
Update:
first
i want to Give a big ***FAIL*** to EK
i tried in 2 diferent case and same thing (caselabs M8 and LD PC-V4)
i cant lock the gpu in PCIe slot because the block on GPU sit on Motherboard water block screw......serious??????? why not use the same screw as the plate on GPU (Flat head screw)
pics
and same thing for the second card lolll
i dont have tools to modify tu use flat head screw
anyway
go to Update
some pics
Last Update for this week, need return working on the road for a couple of weeks
i know, no rad are installed but wnat to do a leak test becaus i splited all waterblock and want to be sure no block leak
next steps,
painting 9 more fans
painting 2 x 360 rad
cable management
installing fan and rad
real leak test and done
more update soon
Thanks
6 REPLIES 6
abvolt
Level 11
Wow that looks really good nice job guy.
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
upsnef
Hi guys
little update on my Red Poseidon
still missing sleeving for USB cable for Aquaero and some little things and a spectacular power cable
but have some pics with rads and painted fans
I put some fan grill, nit sur I will keep them
need your input on this
First, Fannblade Feet with plastidip and red oil-seal, IMHO a perfect match
pics from left, no, right heuuuu, I really don't know witch side is :ROFL:
with a HUGE Strider 1500 and all cable, not enough room for all cable, need to do some magic
other side, relace 3.5 hard drive cage for pump top and pump, you can see my QDC
Top View,ahhh White, red and Black for ROG theme, I love it
this pics is perfect for a EK publicity, I think
I really like EK supremacy painted white with red coolant
some other cool shoot
pretty close to the end of this project
cant wait for new case , and working on new project (Sand of God)
Thanks,
Hey, I love what you've done with this mod.
Are those fans modded and if so, how?!
I'd appreciate any info you can provide. 😄
Retired
Not applicable
yes i must say, i am not the guy who likes HW painting in general..
But your computer looks very good, nice taste, and very well completed..
Good stuff..;)
NerdyBro007
Well after a little research, plasti dip seems to be the secret ingredient. ;D
Antronman
Looks amazing.
Would've been better if the cards had been the RoG Poseidon cards, but I understand that you can't trust those blocks.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
