Results 1 to 3 of 3
    New ROGer Array
    Sep 2013
    1
    Angry G75VX Random Wifi Disconnect
    About a few months ago my WiFi would randomly disconnect however, I doubt it's my modem/router's fault as I'm able to reconnect almost immediately and other devices are unaffected.
    It then stopped having the random D/C so I ignored it but it has recently came back again. My wireless driver is updated and I have tried contacting Online Tech Support and they suggested I send it to a repair centre however, THAT IS THE LAST THING I WANT TO DO.
    Anybody able to help?
    Regards,
    AznJzn
    ROG Guru: Orange Belt Array Prostar Computer's Avatar
    Jul 2013
    11
    462
    Try reloading the driver for your wireless card. If it continues to disconnect randomly, then look into this utility.
    If you're still not running as normal even after running that utility and reinstalling the driver, then the last place to look to is your router. You can try power cycling it and check the router's settings.
    We customize Asus, MSI, and Clevo laptops!
    New ROGer Array
    Oct 2013
    4
    Dont install that is scam...
Tags for this Thread
