Results 1 to 6 of 6
    New ROGer Array
    Sep 2013
    1
    G750JX Tinny sound?
    Just got a G750JX and noticed the sound is really tinny.. does anyone else have this problem?
    ROG Guru: Yellow Belt Array Flea0's Avatar
    Jun 2013
    21
    211
    try adjusting the equalizers in the realtek audio settings, specificaly with the waves maxxaudio software. the "multimedia" setting works best for me.
    ASUS G750JX -- i7-4700 - 16GB - 128GB 840 PRO SSD + 1TB HDD - Nvidia GTX 770M - 120Hz 3D glossy display
    ROG Guru: Platinum Belt Array hmscott PC Specs
    hmscott PC Specs
    Laptop (Model)Asus G750JH-DB71 (legacy)
    MotherboardAsus G750JH Intel HM87
    ProcessorIntel i7-4700HQ XTU Cores 36x/35x/34x/34x Cache 36x -50mV undervolt
    Memory (part number)Hyundai Electronics HMT41GS6AFR8A-PB 1.35v DDR3L-1600MHz
    Graphics Card #1Nvidia 780m Asus GPU Tweak OC 932mhz/6300mhz
    Sound CardRealtek v6.0.1.7469 driver
    MonitorAUO B173HW02 V1 Custom Refresh 85hz
    Storage #1RAID0 2x M.2 SATA Crucial MX200 512GB CT500MX200SSD6
    Storage #2Crucial 512GB 2.5" MX200 CT500MX200SSD1
    Power Supply230w AC Power Adapter 19.5v
    Keyboard Logitech k400 Wireless KB/Trackpad
    Headset Sony MDR-XB500 Wired and Sennheiser RS-220 Wireless TOSLINK
    OS Windows 8.1 + 8 Linux VM's + Windows 10 Technical Preview
    Network RouterAsus RT-AC68U DLINK DIR-655
    Jun 2013
    44
    5,357
    The Realtek HD Audio Manager has several settings areas that can add / reduce tinniness to the sound.
    The setting that can make the sound the "tinniest" is the Internal Subwoofer Slider under the Speakers Tab. Moving the slider all the way to the left/minimum setting shows how much the Subwoofer is helping solidify the sound.
    Checking the Loudness Equalization checkbox under the Speakers=>Sound Effects tab helps fill out the sound.
    Under the same tab, I leave the Environment and Equilizer drop down menu's set to <None> - you might like them - but they can add sibilance or tinny sound elements
    Under the Speakers=>AudioWizard, Launch the MaxxAudio or ROG AudioWizard to select spatial effects. Although it is fun to have the effects at times, I prefer OFF for a lot of material - it pulls in the Sound and makes it less Airy - and less tinny.
    ROG Enthusiast Array
    Sep 2013
    25
    to add make sure u get the newest realtech audio driver, u can find it a couple posts down they came out a couple days ago. the drivers that came installed on my 750jw were pure crap. after i installed new realtech drivers the sound profile litterally doubled like the computer got twice as loud under the same exact settings. plus i got the ROG maxx audio mini program that apparently was disabled by or didnt work correctly witht the initial drivers. personally in my honest opinion if u care anything about sound then i would get a external speaker, a good 1 like my bose bluetooth soundock. cost 300 bucks but its the greatest electronic purchase i have ever made period. only reason i cared about laptop speakers wasd because i spent 1400 on a laptop and felt i wanted every ounce of productivity out of it that it was capable of giving. cheers hope the driver bit helps .
    ROG Guru: Orange Belt Array Prostar Computer's Avatar
    Jul 2013
    11
    462
    How audio quality is perceived is so relative to each person that it's hard to say whether it's an EQ configuration or you just may not like the speaker quality. If your drivers are current and everything is working on that front, then try playing with the Realtek audio manager or MaxxAudio settings. Small adjustments go a long way.
    If you think there is an issue with the speakers, you could get in touch with Asus then. It's possible the woofer isn't working.
    We customize Asus, MSI, and Clevo laptops!
    Sep 2013
    25
    i agree with prostar, its all relative. although once u hear real sound quality its hard to even contemplate anything south of it. anyone who truly loves music understands that. poor speakers is like viewing a painting through glasses that turn down the colors, sure u can still appreciate the art but not to its fullest extent. some people listen to hip hop with out a sub and it just blows my mind that they either dont care or dont know any better. hope u get it sorted out cheers.
