Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 74
    ROG Guru: Orange Belt Array chrisnyc75's Avatar
    Jul 2013
    63
    413
    First custom watercooling build: seeking feedback/advice
    So, I’ve decided to take on my first custom watercooling build to go with my upcoming IB-e upgrade. I’ve done quite a bit of research and formulated an initial build and setup plan, and am now at the point that I want to run it by the experts here and solicit feedback & advice.
    To start off with, here’s a VERY rough diagram of what I expect my build to look like (please forgive my horrendous artwork, but you get the idea):
    My planned loop is: pump > res > cpu > rad > gpu > gpu > rad > pump. I would like to be able to mount the pump directly under the reservoir, allowing me to make that last connection shorter and more direct, but I need to see the case first to figure out if that’s possible. Where I have the pump in the diagram (bottom right corner) is the designated default pump mount.
    I’m still working out how many additional fittings (i.e. 45 degree, 90 degree, etc) I’ll need.
    Now, a few notes on the less obvious choices I’ve made:
    One thing that concerns me about this build is fan noise. I’ve never been one to be concerned about fan noise, but I’ve also never planned a build with 15 fans before. lol I’m concerned that 12 Corsair high-flow fans at full speed could sound like a freight train, so I’ve made some compromises. I figure with 2 large radiators + 12 fans, I can afford to dial back the rpms & airflow just a bit in favor of less noise (Swiftech, on top) and aesthetics (the red Phobya, on bottom).
    For the top radiator, I went with the XSPC low profile 36mm radiator because I have exactly 70mm clearance between the top of the case and the top of the mobo. To compensate for the slim form factor, I decided to go with the (3x)140mm model. This will allow me to have the top radiator in push-pull config while not conflicting with the NB heatsink or ram. I could, of course, have gone with a thicker radiator (up to 70mm) and just one set of fans, but I think it’s more effective to go with the thinner radiator w/ push-pull since the top will also serve as the main air exhaust – I want to make sure I don’t get warm air building up inside the case faster than it can be exhausted out the top.
    I have made a conscious effort to keep all components in the system pure COPPER/BRASS, no nickel; and I do not plan on any additives to my H2O (besides the silver killcoil). My understanding is that this should keep my system from reacting with itself and keep my components clean and operational with minimal maintenance (clean/flush once a year or so).
    I'm not thrilled with the the idea of using cold cathodes for lighting, but I don't think I've ever seen a UV LED (?). I could just go with red LEDs, which is what I have in my current build, but I rather like the idea of highlighting the tubing with UV light.
    I considered going with universal gpu blocks instead of full coverage, but I intend to overclock the crap out of my graphics cards once I get them under water, and I'm not sure how the voltage regulators would do with passive cooling. I'd love to hear insight on universal vs full coverage gpu blocks. If I could go with universal blocks it would save me a lot of money down the road when I decide to upgrade my graphics cards, but I don't want to go that route at the expense of overheating VRMs.
    Finally, the Enthoo Primo chassis won’t be available for purchase until mid-October, so I have a few more weeks of planning to do before I can get my hands on it, but that just gives me plenty of time to be meticulous about planning.
    I think that about covers it. Any & all feedback, advice, or insight is welcome and appreciated.
    Thanks!
    Asus RIVBE • i7 4930K @ 4.7ghz • 8gb Corsair Dominator Platinum 2133 CL8
    2xSLI EVGA GTX 770 SC • Creative X-Fi Titanium • 2x 840 SSD + 1TB Seagate Hybrid
    EVGA Supernova 1300W• Asus VG278H & nVidia 3d Vision
    Phanteks Enthoo Primo w/ custom watercooling:
    XSPC Raystorm (cpu & gpu), XSPC Photon 170, Swiftech D5 vario
    Alphacool Monsta 360mm +6x NB e-loop, XT45 360mm +6x Corsair SP120
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,400
    Looks like a good project!
    Just a question first...order...I guess you didn't mean this but your order sounds backwards...like the res before pump is the only real order rule...res>pump>rad>gpus>rad>cpu>res>pump> right?
    Yes you can dial down the noise a bit...of course you might drop a bit of performance compared to screaming fans through high fpi rads but nothing mind blowing....it will cool well ..
    The coolant I would say great....I run deionized only and just change it regularly....I have just taken apart block andit was almost clean as a whistle....just a bit of crud from RADS....you could do worse than to thoroughly flush new RADs before you set up loop I reckon....
    Also I know angled fittings are nice and at the end of the day aesthetics play their part..but try to keep these to a minimum for best flow...especially 90 degree fittings...
    That pump is great on high flow low restriction loops so you want to keep it that way...maybe even consider parallel flow through GPU's; keeps pressure drop down in the loop as a whole and therefore flow up...(though flow through each GPU block is half loop flow)
    ROG Guru: Orange Belt Array fbm211's Avatar
    Mar 2013
    380
    You might be able to save some coin by checking out performance PC. I saved close to 50 bucks on my project.
    And just a heads up.... Cooler master is coming out with a really cool new case.....modular. with stackable Rad boxes. Very cool.
    G1 Sniper 3
    Intel i7 3770k @ 4.7ghz
    Custom Water Cooling
    Gskill Trident X 2400 mhz-CL 9 @ 2450
    GeForce GTX 970
    VelociRaptor II 150
    XFX 850 Black Edition PSU
    Cooler Master HAF X
    Acer G245H 24 inch monitor
    Klipsch Pro media v2 400
    ROG mouse
    ROG Keyboard when available
    Jul 2013
    63
    413
    Quote Originally Posted by Arne Saknussemm View Post
    I did not know that, but that's easy enough to correct, especially if I can mount the pump directly below the reservoir and just re-route the tubing (vs my poorly rendered diagram lol)
    I actually think I've managed to make good choices in fan performance while being very conscious of noise. Of course I could have gone with 12 3k rpm Scythes, but my system would sound like a leaf blower. lol I'd like to be able to HEAR the games as I'm playing them.
    This was a point of some confusion for me. From what I've gathered, there's 2 schools of thought -- the purists, who say pure H2O is the only way to go, and the progressives, who say companies spend millions on r&d to come up with high tech coolants that outperform pure H2O. I'm not sure who to believe, but at the end of the day going with the purists just feels more logical to me. Plus, I'd rather not have to disassemble the system for maintenance all that often, and I believe pure water requires the least maintenance, correct?
    And yes, I plan to thoroughly flush/clean the entire system before I fire it up.
    Great point, I still need to figure out my SLI cooling design. I probably will go with parallel flow.
    Quote Originally Posted by fbm211 View Post
    Thanks for the tip. As you can probably tell, cost has gone right out the window as a consideration in this design, but still, if I can get the same component for a penny less, that's a penny left in my pocket at the end of this project (which is probably about all I'll have left at this rate LOL)
    I've seen the new Stacker, but it's not for me. It was love at first sight since I first laid eyes on Phanteks's Enthoo Primo, it's like the case I've been waiting for all my life. lol
    Apr 2012
    481
    13,400
    Must say...that case is a nice case...and they've obviously done some WCing thinking...FAQ page....good choice!
    The coolant... purists are right...can't argue with the physics. The mixed liquids actually can be left longer without draining etc so maybe less maintenance....I change my coolant every 8 to 10 weeks...just to make sure it is not growing anything and to make sure it is still deionized. As soon as you add anything to loop and as soon as water runs in loop it is picking up ions and slowly degrading in that respect...but deionized water is cheap as chips so changing it is a breeze if you plan your loop so you can drain and fill it easy....
    Jul 2013
    63
    413
    Thanks, I'm excited about it. I had been considering a full tower watercooling build for some time, but as funny as it may sound to say, I was held back because I simply couldn't find a case that felt right. They were all either too flashy/gaudy, too big, too expensive, or too something. Then I laid eyes on the Enthoo Primo, and like Goldilocks said it felt "juuuuuust right" Only thing wrong with it is the color of the LED strip on the outside, but that's easily enough changed with a quick mod.
    Check out this review, it's REALLY thorough with lots of great info about watercooling in the case: http://themodzoo.com/forum/index.php...eview-r67?pg=1
  7. #7
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    if you want to monitor water temp heres a good one -> http://www.frozencpu.com/products/13...Pin_71170.html
    one or 2 of those, just be shure the whire is long enough to reach the fan controller.
    i have one in the loop and i have a temp sensor on my pump.
    cable is 50cm long.
  8. #8
    Jul 2013
    63
    413
    Quote Originally Posted by kkn View Post
    cable is 50cm long.
    Thanks, I'll keep that in mind. I'm not 100% sold on the fan controller in my original post, I may ultimately go with one that has temperature monitoring and pwm built in, but I haven't quite found the right one yet (has to have at least 2 channels each with a high enough rating to power 6 fans)
  9. #9
    Aug 2011
    243
    6,112
    Quote Originally Posted by chrisnyc75 View Post
    just look at the specs of the fans, look at Amp and Watts and see if it goes abow the max limit of the controller.
    i have Y-splitters on my fans and have one and one rad on each chann.
    if you drop 3 fans on each rad you can make it thicker and have more cooling surface, if thats an option.
    i had push/pull on last built, but now i have ( 1 ( 360 ) TOP -> push , 2 ( 240 + 480 ) on bottom -> pull ) ( build log = overkill )
  10. #10
    Jul 2013
    63
    413
    The bottom has an incredible amount of space, so there's no need to drop fans there, I can do push/pull plus the Black Ice Xtreme with lots of room to spare. On the top, I could go with a thicker rad (maybe a second Black Ice GTX) with just one set of fans, but the fans would have to be pull (above the radiator) due to space restriction inside the case frame. I struggled with which design made more sense, but I feel like push/pull on the top is important if only to ensure sufficient warm air exhaust since every other fan in the build is pulling air INTO the case. I feel like the 60mm thick GTX on the bottom plus the 36mm thick XSPC on the top should be more than sufficient surface area for cooling just my cpu + 2 gpu's, no?
    The fan controller I have listed above has sufficient watts per channel to drive 6 fans each; but it does not have pwm built in, and thus can't be used to control the pump (which I'll probably just connect to a mobo pwm header), and doesn't have a temp monitor input. But like I said, I'm not married to that fan controller, if I find one with better features rated for 30W per channel (at least 2 channels) I could be swayed to go with a different choice.
    *edit: the fan controller I listed above DOES accept temperature monitoring inputs (I zoomed in on the far right, it has 4 inputs for temp monitoring), so the only thing it's missing is pwm, which is actually fine with me. I'll add one of those phobya sensors to my list and monitor it through the controller display...thanks kkn.
