Results 1 to 5 of 5
Thread: Rampage IV Fan Control
09-20-2013 06:11 PM #1
- Join Date
- Jul 2013
- Reputation
- 10
- Posts
- 18
I seem to be having trouble controlling my PWM pumps inside windows. I have no interest in using the bios do this for me, and want to make the adjustments in the OS. Using Speedfan, adjusting say the CPU fan speed (I have a pump connected there), does not seem to affect the pump at all.
Is it related to settings in the bios?
09-21-2013 02:23 PM #2
It's more likely your fan isn't PWM enabled, see the explanation in the link below, it may help:
http://www.swiftech.com/pwmcontrollers.aspxAsus RIVBE • i7 4930K @ 4.7ghz • 8gb Corsair Dominator Platinum 2133 CL8
2xSLI EVGA GTX 770 SC • Creative X-Fi Titanium • 2x 840 SSD + 1TB Seagate Hybrid
EVGA Supernova 1300W• Asus VG278H & nVidia 3d Vision
Phanteks Enthoo Primo w/ custom watercooling:
XSPC Raystorm (cpu & gpu), XSPC Photon 170, Swiftech D5 vario
Alphacool Monsta 360mm +6x NB e-loop, XT45 360mm +6x Corsair SP120
09-22-2013 03:35 AM #3
- Join Date
- Jul 2013
- Reputation
- 10
- Posts
- 18
I actually have one of Swiftech items, the apogee drive II with a MCP35X on it. I have it plugged in on the CPU pin on the motherboard. The device itself is powered by molex, but also has a 4 pin connector that is on the CPU fan pin header. Additionally, I have two more pwm MCP35X on the OPT 1 fan header. I cannot control any of them. I have tried disabling all points in Q fan under the fan option in the menu. Is there something I am doing wrong?
09-22-2013 03:36 AM #4
- Join Date
- Jul 2013
- Reputation
- 10
- Posts
- 18
Also, thank you for that reply. Although I have seen that exact page before, I do appreciate the effort.
03-06-2020 03:11 PM #5
- Join Date
- May 2012
- Reputation
- 10
- Posts
- 71
Intel 3770K 4.4ghz, 1.24v. . . . . . . . . . . . . .Intel 4930k 4.7ghz 1.37v
32 gGSkill DR3Trident 2400mhz 1.65v. . . .32 g 1866 Vengeance Pro
ASUS M5G. Noctua D14. . . . . . . . . . . . . . . H110. Noctua A14x4
prime95 stable 78degrees. . . . . . . . . . . . . IBT 75 degrees
OCZ V4 OS. . . . . . . . . . . . . . . . . . . . . . . . . EVO 1TB
Seasonic 700w. . . . . . . . . . . . . . . . . . . . . .1200AX
All tucked into Lian Li A05. . . . . . . . . . . . . .Fractal Midiv2
