Why Hello
Can i get some input reagrding an issue i am seeing with my rig.
Whenever a resart is requested(manually or via the OS) i get a QLED code of 05 seconds after the OS has terminated. Hitting the restart button sometimes works but not always. Holding the power button to force power off also 'sometime works' but killing the actual power is the only true workaround. Only had this rig setup 3 days and had this issue during install of the OS.
Running Windows 7 64bit
Crosshair V Formula Z
AMD FX 9590 OC to 5016mhz + Corsair H100i Liquid Cooling
16GB (2x 8GB) Corsair Vengence Pro Silver OC to 2133mhz
Single AX7790 1GBD5-DH - 1GB PowerColor Radeon HD 7790 OC, 6000MHz GDDR5, 28nm, GPU 1075MHz, Cores 896
OCZ-Agility3 128GB SSD
Coolmaster Silent Pro M1000w PSU
Thanks in advance.
The Rig
All fitted into a Corsair C70 Gun Metal Black Mid Case
