Well Moose what are your temps running??? if your having high temps your fans are trying to prevent damage to you NB, You can download and install
hwinfo64 run the sensors that will show you your temps and fan speeds.
And to answer your question no the fans on these G75 are very quite even under heavy loads. You may want to return this unit before you return to vender time is run out.
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
