Results 1 to 10 of 10
    ROG Member Array
    Sep 2013
    5
    Normal running temp?
    Got a new 750JW and i'm mostly on swgemu, some steam games but nothing too crazy. Temp sticks around 58c sometimes lower, sometimes a little higher. is this normal?
    ROG Guru: Platinum Belt Array hmscott PC Specs
    hmscott PC Specs
    Laptop (Model)Asus G750JH-DB71 (legacy)
    MotherboardAsus G750JH Intel HM87
    ProcessorIntel i7-4700HQ XTU Cores 36x/35x/34x/34x Cache 36x -50mV undervolt
    Memory (part number)Hyundai Electronics HMT41GS6AFR8A-PB 1.35v DDR3L-1600MHz
    Graphics Card #1Nvidia 780m Asus GPU Tweak OC 932mhz/6300mhz
    Sound CardRealtek v6.0.1.7469 driver
    MonitorAUO B173HW02 V1 Custom Refresh 85hz
    Storage #1RAID0 2x M.2 SATA Crucial MX200 512GB CT500MX200SSD6
    Storage #2Crucial 512GB 2.5" MX200 CT500MX200SSD1
    Power Supply230w AC Power Adapter 19.5v
    Keyboard Logitech k400 Wireless KB/Trackpad
    Headset Sony MDR-XB500 Wired and Sennheiser RS-220 Wireless TOSLINK
    OS Windows 8.1 + 8 Linux VM's + Windows 10 Technical Preview
    Network RouterAsus RT-AC68U DLINK DIR-655
    Jun 2013
    44
    5,357
    58c is about right
    What is your room temperature there? Mine is 74.6'F right now.
    Here is a snapshot of the range over 10 minutes, while browsing in Windows, running Linux(s) under Virtualbox, and watching a streaming video on RedboxInstant. I had set back to stock speeds a little while ago, so these readings are also at stock speeds.
Name:	Normal runing temp.JPG
    And here is a 10 minute snapshot after restoring full OC and -60Mv voltage offset for CPU/cache
Name:	Normal running temp max OC -60Mv 10 min.JPG
    ROG Member Array
    Sep 2013
    5
    Room temp is normally about 68 (unless the wife feels the need to increase it, silly girl, to 70) I'm stuck in a little folding desk type of thing in the living room against an exterior wall at a large window (so it's a little cooler on that wall. I'm near a forced air floor heat register but I've got the air deflected from it with one of those nifty little plastic/magnetic airflow diverting things made for vents. I've got curtains that are sometimes open, sometimes closed but I keep the back of the laptop at least 8 inches away from the wall/curtains to avoid having the computer ingest it's own magma like noxious heat fumes
    I bought a cooler master notepal x3....noticed no cooling so returned it and got a coolermaster sf 19.....but I haven't had time to mess with the new one. I've never really given much clout to laptop coolers....seems like a gimmick to me but it's got big fans, looks and sounds obnoxious with the pretty multi-colored lights, so it's a keeper. What's your opinion on coolers? I've always thought that anything stiff and flat for those in-bed movies will keep the bottom sucking good air and vents not closed off.
    ROG Guru: Orange Belt Array
    Jul 2013
    41
    325
    This laptop sucks in air from just under the screen hinge (i.e. from the top/keyboard panel). As such, any cooler pad with fans blowing air at the bottom of the laptop will be more or less useless.
    hmscott PC Specs
    Jun 2013
    44
    5,357
    Quote Originally Posted by Mikon View Post
    A cooler pad won't help much, Better would be a fan behind the laptop blowing away the hot air coming out of the vents. When doing normal work the hot air output isn't much, but if the laptop is kept near a wall, in a corner, the area will fill up with warm air over time, raising the ambient temperature of the air the laptop is sucking in for cooling.
    Run something that logs the temp over time, like HWinfo64 or AIDA64, and get a range of temps that match up with collected CPU utilization to see idle temp and load temps.
    Just picking one temp out as a single sample doesn't say much. 58' is not good if it is the lowest idle temp ( 0% cpu utilization for a stretch), but if it is the temp you get while doing work, loading the CPU, it isn't bad. You need to put the temperature readings into a context of work the laptop is/isn't doing to be useful.
    As for the floor vent, get a pre-made vent deflector, or make a deflector out of cardboard/wood and duct tape (the heat reflecting kind) to reflect the heat away from your work area. Better you are cold, and the laptop is cold
    Do a longer running benchmark, heat up the CPU, and put your hand in the air stream coming out of the left vent, feel how forceful the output is and the extreme heat - 8 inches is likely too close to the wall - especially if the desk goes up and touches the wall - containing the heat. Pull the desk away from the wall, or face the back of the desk toward the center of the room - who wants to face a wall all the time?
    ROG Member Array
    Sep 2013
    5
    Thanks for the awesome tips
  7. #7
    hmscott PC Specs
    Jun 2013
    44
    5,357
  8. #8
    New ROGer Array
    Oct 2012
    13
    2,441
    i think it is good temp, if some peopl will get high 80-90 temp when they play high loading game.
  9. #9
    ROG Member Array
    Oct 2013
    15
    Those temps are perfectly alright, keep in mind this is a haswell too ^^
    Some brands like Hp and Dell (aka crap), have really poor cooling exept for dells alienware ofc, single fan units that are mounted wrong and with minimal copper>< had an envy 15 touchsmart, it had superb hardware in it, but when it came to cooling it was a vacuum cleaner and a hot one :P
    Also with a cooling pad you wont getmuch out of it, i sawed a piece of wood and have that as a firm "plate" under it, so i can just pick it up and sit on the couch ^^ also way cheaper option
  10. #10
    ROG Guru: Orange Belt Array Prostar Computer's Avatar
    Jul 2013
    11
    462
    Quote Originally Posted by rawpure View Post
    Haswell TDP is lower than last gen, so the Intel chips should technically run a bit cooler. It's the 7xxM NVidia cards that run hotter this generation.
    58 C is stable. It could be better, though your main concern is temps under load!
    We customize Asus, MSI, and Clevo laptops!
