10-15-201308:19 AM - last edited on 03-06-202407:18 PM by ROGBot
Hey guys. First post 🙂 I'm about to buy a new sub for my G75. I've had this issue since the beginning. The subwoofer seems like it's blown, it's vibrating when playing deep sounds. Before I spend the cash, does anyone else's sub do the same thing? Here's a youtube bass test that really shows off the vibration on my laptop.
Sounds like putting a playing card into a bicycle rim. cheers 🙂
Do you really think you are going get deep bass from a small bass driver? That's ultra low frequencies, and is not meant for such a small bass driver!! It's not a 15" PileDriver Sub....lmfao!
Be advised, turn down the volume before running that YouTube Video!!
PS: Yes it's normal!
GottiBoi55 Asus G750JZ-DS71 Windows 10 Pro (x64) Intel® Core™ i7 4700HQ (2.40GHz) Samsung 24GB Memory DDR3 1600 MHz SDRAM SanDisk M.2 SSD 2x128GB in Raid 0 / WD-HGST-1TB HDD 7500-RPM NVIDIA® GeForce® GTX 880M 4 GB GDDR5 VRAM Second Monitor: Sharp Aquos 32"
Thanks for the replies. I can hear the same vibration playing normal music. For example, here's a link to youtube (Tron soundtrack). For example, when I forward to 46:30min, and listen, I can definitely hear the bass speaker vibrating.
If this is not normal (I'm assuming it's not), then I'll just order a replacement speaker. They're pretty cheap anyways. But if all the bass speakers have this issue, replacing it wouldn't make a difference. Again, thanks for your help! cheers, Indy 🙂
