Results 1 to 3 of 3
    ROG Guru: Yellow Belt Array TheOriginalTO's Avatar
    Jan 2011
    136
    Wireless adapter question
    I am using the Atheros AR9285 Wireless Network Adapter but for some reason in device manager it puts a #2 at the end of it like so Atheros AR9285 Wireless Network Adapter #2.
    I've tried re-installing the driver etc but it persistently says it is #2. could this be a bug or something?
    -Thanks.
    You Heard It From - ']['he (())riginal - ']['.(()).
    Jun 2011
    15
    132
    For some reason windows thinks that your wireless adapter is new. Its labeled as number 2 since windows thinks that there is another "Atheros AR9285 Wireless Network Adapter" installed on your system just not plugged in or disabled and wants to avoid a conflict if the first adapter returns. The label does not affect your connection
    Jan 2011
    136
    alright, but it's odd that it thinks that :/
Similar Threads
  1. my power port broke, the adapter ate the center pin.
    By reiyu in forum G Series Gaming Notebooks
    Last Post: 08-06-2014, 10:50 AM
  2. Wireless question
    By Farroo in forum G Series Gaming Notebooks
    Last Post: 03-28-2011, 05:13 PM
  3. wireless adapter question
    By darkvesperia in forum G Series Gaming Notebooks
    Last Post: 03-22-2011, 05:02 PM
  4. angled L/90º power adapter
    Last Post: 01-04-2011, 06:22 AM
  5. angled L/90º power adapter
    Last Post: 01-04-2011, 05:20 AM
