Results 1 to 7 of 7
    Parsaiej
    Guest
    Monitor will not turn on after a BIOS tweak!
    Hello everyone, I felt that this was the best place for me to come to as it has already helped me out with various problems I have had with my G73. Essentially, my problem today is that my laptop's monitor will not turn on at boot, however, It clearly is powered with the fans spinning and the lights (excluding keyboard) on. The last thing that I had done before this problem was disabling my touch pad in the BIOS. All I did was disable it, and then just save, exit, and reboot to be welcomed with an unresponsive monitor. So far I have only tried pulling out the AC and battery and pressing the little reset button with a paper clip (supposedly resets BIOS). I also tried doing the method of hitting the power button 5-10 times. Tomorrow, I plan on getting one of my external monitors in the attic so I can find out if this is all because of some lose wire, or something way more serious. A last resort is to open up my laptop and reset the CMOS battery. If anyone has any information on how I can resolve with problem will be greatly appreciated.
    ALSO - Instead of having all for LED activity indicator lights lit up on the front of the laptop, only the one with the lightbulb and the battery show up. The CPU LED only comes on for a little bit at boot, but then goes out. The Caps and Nums lock that usually just flash at boot just stay lit up forever while the monitor is blank. These lead me to believe that this could be a problem a little more complex that a loose wire.
    Thanks in advance
    TeamROG Notebook Member Array Chastity@ASUS's Avatar
    Oct 2010
    18
    1,334
    I would try using the external and see if you can get into the BIOS and reset it to defaults. After confirming it works, then make your edits.
    Kicking Ass Since Today
    Parsaiej
    Guest
    Well it seems that hooking up my external monitor is not working either. It looks like the only options that I have left is to either reset the CMOS or just RMA it. Which should I do?
    Oct 2010
    18
    1,334
    I don't know how competent you are at opening the chassis.
    Parsaiej
    Guest
    Well you know I have opened it up time to time to clear all the dust build-up and do know to refer to that useful video on disassembling the laptop haha, and I have all the tools at my disposal to do it except for the anti static wrist thing
    EDIT - Ok I'm looking at the battery right now, I'll tell you guys if it worked or not when I get the thing all put back together.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    300
    7,445
    The anti-static isn't critical if you don't generally have high static problems where you are working. Just make sure that you touch something grounded before you touch anything sensitive in the machine. Once you've discharged just don't shuffle around and you shouldn't build any charge. Oh, and perhaps avoid the polyester suit and wool socks. I know it's tempting but just stick to cotton while you're working
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
  7. #7
    Parsaiej
    Guest
    YAY! Reseating the battery seemed to have done it, I am so happy to have this resolved and wanted to thank you both again for the help D!
Similar Threads
  1. Can't seem to turn on keyboard backlight on G53
    By Lionel Leow in forum G Series Gaming Notebooks
    Last Post: 12-30-2013, 06:41 PM
  2. GPU Tweak (Beta)
    By Brian@ASUS in forum ASUS Software
    Last Post: 06-14-2012, 05:33 PM
  3. Quakecon over but I'm not ready to turn in :)
    By The Nemesis in forum General Discussion
    Last Post: 08-07-2011, 07:44 PM
  4. I need info on Tweak RC on the Gene Z
    By Area 66 in forum Other Series Motherboards
    Last Post: 07-23-2011, 05:19 PM
  5. Help! I flashed my BIOS and now can’t turn on my G73JH
    By Galactica in forum G Series Gaming Notebooks
    Last Post: 03-17-2011, 06:51 PM
