My new Build (NEED Some help)
stigping
Hi, i have ordered a new computer and just want to know if all fits all right.
Cooler Master Storm Trooper
ASUS Maximus VI Formula
XFX ProSeries XXX Edition 850W PSU
ASUS GeForce GTX 770 2GB PhysX CUDA (I'm going to have 3-way SLI as soon as i have the money)
i7-4770K
CoolerMaster Hyper 412S
Corsair Vengeance Pro DDR3 1866MHz 16GB
i have already installed:
4x Hard drives and 2 DVD Drives but no SSD's
Hope you can help me 🙂 i'd like some tips and/or if you can tell me what to buy instead.
CPU: i7 4770k 4.7Ghz 1.425v
MB: Maximus VI Formula
RAM: G.Skill Ripjaws Z DDR3 1866MHz (4x4) 16GB
GPU1: ZOTAC GeForce GTX 770 4GB
GPU2: ZOTAC GeForce GTX 770 4GB
PSU: XFX ProSeries XXX Edition 850W PSU
SSD: Samsung SSD 840 EVO 120GB
HDD1: Seagate Barracuda 2TB
HDD2: Seagate Barracuda 3TB
Case: CM Storm Trooper Gaming
Mouse: SteelSeries Sensei RAW
KeyBoard: Razer Blackwidow 2013
Monitor: BENQ XL2420T
6 REPLIES 6
Zka17
Level 16
Welcome to the ROG Forum!
If you want to go 3-way SLI, then you will need to upgrade your PSU too... perhaps over 1000W - but right now it's fine
Not sure why you need so many HDDs, but an SSD for the OS and other applications will be the most rewarding upgrade...
it is Hard drives from 2 of my other computers and its only about 860GB or so.
do i need to upgrade my psu if i go 2-way? and what if i buy the 780Ti?
Arne_Saknussemm
Level 40
Hi stigping 🙂
All looks OK to me except I wonder about the cooler. If you are getting the 4770K I presume you will want to be OCing it? If so, I would say you should think about a really high end air cooler or a H100i. The 4770Ks are hot CPUs and are limited by what you can get out of them by heat so the cooler you can keep it the better.
Tri SLI and you might want a bigger PSU too....
i dont like liquid cooling systems because it takes time to clean and stuff so if theres any good fans that will fit in here, i will take a look at that! 🙂
i have checked some noctua's.
Arne_Saknussemm
Level 40
Or this http://www.coolermaster.com/product/Detail/cooling/cpu-air-cooler/v8-gts.html
The liquid cooling H100i is closed loop so there's no cleaning the loop etc if that's what you mean. if you buy a coupke 780tis I would go 1000w min or 1200 for max comfort running all that OCd
