Guys, I have posted about adjusting the Subwoofer level to less than 70 out of 100 before, but I took some time to find the MAXAudio level needed to remove the buzzing with the Subwoofer level at 100/100, and thought you might try it to reduce the buzz/static/disconnect as the sub is over-driven.
The 250hz slide is the one that affects the buzz on my G750JH, it needs to be dropped down way far to completely get rid of the buzz, this is how I have it set to run without buzzing at 50/100 overall volume level:
I still get the occasional zip from the sub during high volume action sequences, so I will likely drop the Subwoofer level again a bit as I tune it some more.
Update: 90/100 seems to be enough of a drop to remove the occasional distortion now that the 250hz slider is set down as above. Trying to decide if I like it better this way, or with the 250hz slider up to mid setting (default), and setting the Subwoofer Power level at 55/100 as before...
Please post what settings work for you
