11-23-2013 06:24 AM - last edited on 03-06-2024 06:51 PM by ROGBot
11-23-2013 06:30 AM
11-23-2013 06:56 AM
HiVizMan wrote:
Hello
Could you do something for me please. Have a look at the OS event viewer to see what was the cause of the issue.
Now your memory could you please post up the exact part number for your kit. I am assuming it is a singe 4 x 4 stick kit.
11-23-2013 07:02 AM
11-23-2013 10:05 AM
HiVizMan wrote:
Ok all good with the memory that is a 4 x 4 kit. However Vengeance does not like the X79 boards - have seen over 3000 threads about X79 and issues with those memories I kid you not. BUT it should be fixable.
Here is what you do. Set XMP profile and drop your memory frequency to 2133MHz, it could just be your CPU IMC is not up tot he job of running 2400MHz. Now download ROG realbench and run the benchmark twice. If your system passes then you are basically sorted. Not the stress test the benchmark.
11-23-2013 10:13 AM
