How to remove/replace CMOS battery in G75VW
GLTYSPRK343
I have a G75VW-TS71 and currently it is a bricked box. I upgraded the BIOS to v223 using the e z flash utility, and after reboot, my box did not come back. It powers on with status LEDS and humming, but no BIOS screen (it's completely black). The CNTL+HOME options do not seem to work (maybe because i had wiped the harddrives clean when i installed a new SSD and OS?). I was thinking of trying to reset the BIOS to fix, but i do not know where the CMOS battery is located and if it is easy to get too? Any help/pics would be great! Thanks in advance!
Cheers,
Johnny
Pitcher1
i think you better way is sent to service center to replace it.
