Results 1 to 3 of 3
    New ROGer Array
    Nov 2013
    1
    Battery charger g74sx
    Hello
    the battery charger of my asus g74sx is very hot, my idea is to buy the 180 watt one on asus shop but on the specifications this model is not mentioned. Anyone has already bought this supply 180 w for this laptop
    Many thanks
    New ROGer Array
    Oct 2012
    13
    2,441
    i think you buy form asus E-Store, it is ok.
    ROG Enthusiast Array
    Nov 2013
    41
    buy an older 230W from a dell and change the plug on it. tis cheaper than buying a new one. I picked one up on ebay for $30 plus $10 for the new plug with 6' of wiring.
    make sure its a 19.5V output.
