Results 1 to 10 of 51
11-28-2013 08:49 PM #1
- Join Date
- Nov 2013
- Reputation
- 10
- Posts
- 7
Asus Rampage IV Extreme + Core i7-4820K --> debug code 00 and red cpu led
Motherboard model: Asus Rampage IV Extreme
UEFI Version: 3602
CPU: Core i7-4820K
Memory kit part number (s) and amount in GB: G.SKILL Trident X DDR3-2400Mhz CL10 32GB (4x8GB)
GPU: Asus GeForce gtx 670
SSD/HDDs/Optical drives: Kingston SV300S37A/240G 240Gb 2.5" SSD
PSU: Consair AX860i
USB Devices (model/version number):
CPU Cooler: Cooler Master 212
PC CASE: Consair 600T
Operating system: Microsoft Activated yes/no? NO
Drivers Installed (include version): NO
Any third Party temp/voltage software installed: NO
System Overclocked (provide details)? NO Clue yet
Issue
Hi All,
I purchased my matherboard (rampage IV extreme) and psu (Core i7-4820K) one week ago. Since then I am trying to make them work all together but no luck so far. I have read many forum problems which seems to be similar and from these fix suggestions (also from mother board spec), I become sure that I definetely need to update my BIOS from 3602 to latest version 4503.
Then I used the guide below and complete the BIOS update:
http://event.asus.com/2012/mb/USB_BIOS_Flashback_GUIDE/
Things I tried so far:
- USB BIOS Flashback to latest BIOS version which is 4503 --> Not Helped
- USB BIOS Flashback to any other release which is 4403 --> Not Helped
At both case, after the update, error code stayed at 00 and CPU led stay red. No Boot at BIOS nor any display.
Any idea from anyone ?
I will be glad if you can help me on this,
thanks in advance,
11-28-2013 09:02 PM #2
- Join Date
- Oct 2012
- Reputation
- 339
- Posts
- 15,254
Welcome to the ROG forums, cey_yav.
I'll need you to locate a long and thin sticker that contains a barcode and a bunch of numbers. Will need you to post the last 4 digits here for me.
11-28-2013 09:06 PM #3
Arne Saknussemm PC Specs Laptop (Model) Laptop?...No way! (Model?...Jun Amaki...yes way!) Motherboard ROG ZENITH II EXTREME Processor THREADRIPPER 3960X Memory (part number) TXBD48G4000HC18FBK Graphics Card #1 GTX Titan X Graphics Card #2 SLI is dead to me Graphics Card #3 Tri SLI is even dead to Nvidia Graphics Card #4 Quad SLI is dead to everybody especially my credit card Sound Card Xonar Essence STX Monitor ASUS ROG Swift PG279Q Storage #1 Samsung 970/960/950 PRO Storage #2 2x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs CPU Cooler Custom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock Case Nope!...Dimastech Easy XL...let it all hang out man! Power Supply Seasonic 1000 Platinum Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73) Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney! Headset ...firmly on neck Mouse Pad Mouse don't got his own pad man...lives with me Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition Network Router 56k modem Accessory #1 Umm...nice tie? Accessory #2 Err...belt? Accessory #3 3 accessories?! I'm not a girl!!
- Join Date
- Apr 2012
- Reputation
- 505
- Posts
- 13,687
When you haveupdated from 3602 to the other BIOS did the BIOS lights flash for up to and over a full minute? i.e. did the flash look successful?
Have you tried removing the CPU and checking the socket for bent pins?
Seen too many threads like this recently....some have been bad CPUs some bad boards. If you have access to another CPU or board it might be worth testing either with other compatible hardware just to make sure they are working....
assuming BIOS flash is going well...
Also, for now, use only one stick of RAM in the red slot right of the CPU....
11-28-2013 09:34 PM #4
- Join Date
- Nov 2013
- Reputation
- 10
- Posts
- 7
Hi Chino , it was 3602.
11-28-2013 09:53 PM #5
- Join Date
- Nov 2013
- Reputation
- 10
- Posts
- 7
Hi Arne,
BIOS orange led flashed for at least 2 min then become solid orange light which seemed to be a successful install.
I have re-placed the CPU more than 3 times and checked the 24 pin and 8 pin for any misplacement.
I have no access to a new CPU nor another motherboard to check them but If I could not get any result from the forum advices, I am going to go with the asus service or any other computer service that can help me on that.
I also attached 2 pics where may be you can catch something from.
11-28-2013 09:55 PM #6
Nodens PC Specs Laptop (Model) ASUS GL702VW-GC004T Motherboard Rampage V Extreme Edition 10 Processor Intel 3930K C2 Memory (part number) CMZ16GX3M4X2133C11 Graphics Card #1 ASUS STRIX-GTX970-DC2OC-4GD5 Monitor ASUS VG278H Storage #1 3x OCZ Vertex 3 240 (RAID5 - LSI 9361-8i) Storage #2 3x WD2003FYYS (RAID5 - LSI 9361-8i) CPU Cooler Corsair H100i + 4x Noctua NF-P12 Case Coolermaster HAF-X Power Supply Seasonic X-1250 Keyboard Razer Anansi Mouse Logitech G502 OS Windows 10 Pro x64 Network Router Linksys E4200v2 (running TomatoUSB/Toastman firmware)
- Join Date
- Mar 2012
- Reputation
- 266
- Posts
- 4,389
cey_yav, when you flashed with USB Flashback method. Did the led blink only 4 times? Or did it blink for about a minute going faster and faster all the time?
RAMPAGE Windows 8/7 UEFI Installation Guide - Patched OROM for TRIM in RAID - Patched UEFI GOP Updater Tool - ASUS OEM License Restorer
There are 10 types of people in the world. Those who understand binary and those who don't!
RealBench Developer.
11-28-2013 09:57 PM #7
- Join Date
- Mar 2012
- Reputation
- 266
- Posts
- 4,389
Ah, nevermind you posted while I was typing.
Can you please take a high res picture of the CPU socket pins and post it here?
You also check the socket yourself for bent pins. But if you post us a photo of the socket we can help as well.
EDIT: I can also not see clearly if the EATX12V 8pin or 4pin are connected.
EDIT2: One last note powering it like that without a cooler is not a good idea.Last edited by Nodens; 11-28-2013 at 10:01 PM.
11-28-2013 10:00 PM #8
- Join Date
- Nov 2013
- Reputation
- 10
- Posts
- 7
Hi Nodens,
Not just 4 times but it blinked more than a minute (I guess 2 min or so).
It just blinked with steady speed. It did not get any faster nor change the speed.
11-28-2013 10:02 PM #9
- Join Date
- Apr 2012
- Reputation
- 505
- Posts
- 13,687
yeah, that certainly sounds right...and your troubleshooting in general....is the PSU a known good one...if there's no power to ATX 8 pin this can be the result...do you have another PSU just for elimination purposes.
The RAM should work in that slot although the recommended is D1...same difference...
Last thing, as Nodens said.... you need a cooler mounted and fan plugged to CPU fan header right?
EDIT: that consant speed flash doesn't sound quite right to me either...Last edited by Arne Saknussemm; 11-28-2013 at 10:06 PM.
11-28-2013 10:04 PM #10
- Join Date
- Mar 2012
- Reputation
- 266
- Posts
- 4,389
When the flash is going on normally it should increase blinking speed as it proceeds. Perhaps the flashing failed after all. But do check for bent pins before we go any further.
