12-16-2013 05:41 AM - last edited on 03-05-2024 11:42 PM by ROGBot
12-16-2013 07:09 AM
12-16-2013 08:04 AM
12-18-2013 02:07 AM
01-09-2014 06:08 PM
Raja@ASUS wrote:
I'll share with you some emails from a co-worker who has an LSI Megaraid 9240-8i. I t may be of use to you:
After discovering that LSI MegaRaid 9240-8i = Intel RS2WC080, I found additional solutions to try searching discussions about problems with RS2WC080, including this discussion, which ultimately helped fix the problem. https://communities.intel.com/thread/19598
I downloaded IR3_2008SASHWR_FWPKG-v20.10.1-0107 (fw: 2.130.354-1664) from ~Oct. 2011 and flashed using LSI MegaCli (shouldn’t make a difference, but I was more familiar with MegaCli command line syntax) and it immediately began working. I installed win8 to the array, and did not need to load any additional drivers for it to see the virtual drive.
Does not appear this issue is due to our MB, so there’s a chance going back to this FW may help others who encounter similar issue on other MB.
One additional piece that is relevant to users who are installing OS on the array. Based on my testing, the array must first be created on the new MegaRaid firmware BEFORE rolling back to the earlier firmware.
I switched array type (0 to 5) on the old firmware and found that both win7 and win8 installers BSOD. Win8 installer doesn’t event make it past initialization. However, when I created the array on the new firmware, and then switched to old firmware, it seems to be ok.
I will ask HQ if they have the same card as yours - if they do they might be able to replciate and patch.
-Raja
12-18-2013 09:36 PM
12-20-2013 07:01 AM
MAD wrote:
I have the same LSI 9265-8I and the same mobo. After checking and trying around I found the problem is during the boot process only. Just play with the option in the uefi section and I finally get starting mine. It took me several days, even was thinking to change the board. If you continue with this problem I can check on my bios which is the option I have the setting that is working fine. I'm on 4206 too, but it happens to me the first time i install this board, a couple of months ago. Since then, every time I upgrade to a new bios I just change that options and all is flawless again. I also have 2 titan on sli, and a creative x-fi titanium hd, so a lot of cards in the middle and it works fine.
01-04-2014 05:44 AM
