Results 1 to 2 of 2
    New ROGer Array
    Dec 2013
    1
    Cool Consigli per un mio primo overclock
    Salve ragazzi , vorrei overcloccare un po il mio i 7 3770k montato su una maximus v extreme e raffreddato con un corsair H110. Potete darmi qualche consiglio? Grazie mille: Cool:
    ROG Guru: Orange Belt Array EnthusiastBuild's Avatar
    Oct 2013
    59
    255
    Hi, i speak spanish and i think i understand what you are trying to ask mate!
    Overclock in the BIOS, start with something easy like 4.2GHz and 1.24-1.25 core voltage. Run RealBench 2.0 for stability testing ( 3x times ).
    Downloadable here: http://rog.asus.com/forum/showthread...untry=&status=
    Watch temperatures closely with something like CoreTemp or RealTemp! If stable, go higher - same voltage, if BSOD raise voltage 0.1 until stable.
    Hope i could help you out! Let us know how things are going mate!
    Saludos!
    CORSAIR 900D
    ASUS MAXIMUS VI FORMULA
    INTEL I7 4770K @ 4.5 GHZ
    CORSAIR DOMINATOR PLATINUM 16GB @ 2400MHZ
    SLI EVGA GTX 780 SC ACX
    SSD SYSTEM: CORSAIR FORCE GT 120GB
    SSD APPS: CORSAIR FORCE GT 240 GB
    HDD STORAGE: WD BLACK 2TB
    CORSAIR AX860I PSU
    CORSAIR H100I 4 x SP120 HP
