Results 1 to 5 of 5
    New ROGer Array
    Dec 2013
    1
    G75VW Unexpectedly shutting down - NOT a hibernation issue
    OK I'm going to make this quick because the laptop shut down while I was writing a longer version of this post and I lost everything I had written.
    Bought a refurb G75VW on Newegg for my husband's Christmas on December 5th. It's had a couple bluescreens and shut downs since we got it, but nothing like what I have experienced with it today.
    Today I turned it on to put some Steam games on in while spouse is as work and it just keeps shutting down repeatedly with no warning. About 7 times total since 6pm cst. I've disabled hibernation, uninstalled Power4Gear, Instant On and Live Update. I've checked the BIOS settings. It's got most of the current Windows updates (Windows 7) and updates from Asus. CPU temperature is fine, plus I've not been running any games today and the laptop sits on a cooling stand at all times. Event viewer doesn't show any warnings, errors or anything else before the shutdown, and afterwards only logs that the system suffered an unexpected shutdown.
    Is there something I am missing or do I just need to RMA this thing or what.
    ROG Member Array
    Nov 2013
    11
    I would, personally, send this in for an RMA because that should not be happening.
    ROG Guru: Black Belt Array rewben PC Specs
    rewben PC Specs
    Laptop (Model)G55VW-3D
    MotherboardASROCK Z97 EXTREME 6
    ProcessorINTEL 4790K
    Memory (part number)G.SKILL RIPJAWZ 2400MHZ (F3-19200CL10Q-32GBZHD)
    Graphics Card #1ASUS STRIX-GTX980-DC2OC-4GD5
    Graphics Card #2ASUS STRIX-GTX980-DC2OC-4GD5
    MonitorDELL U2713HM
    Storage #1SAMSUNG SM843 480GB X2
    Storage #2WD GREEN 3TB X2
    CPU CoolerSWIFTECH H240-X
    CaseNZXT H440
    Power SupplyTHERMALTAKE TOUGHPOWER XT PLATINUM 1275W
    Keyboard CORSAIR K70 RGB
    Mouse STEELSERIES KINZU V3
    Headset STEELSERIES 9H
    Mouse Pad STEELSERIES QCK+
    Headset/Speakers LOGITECH Z506
    OS WINDOWS 10 PRO AU
    Network RouterASUS RT-AC66U
    Jun 2012
    178
    2,229
    you missed nothing. it is very likely a hardware issue (power related) that cannot be fixed with mere software adjustments. RMA is your best bet.
    a laptop in general is not supposed to act like that, with or without battery.
    ROG Guru: Orange Belt Array
    Jul 2012
    17
    264
    I wouldn't RMA it, I would return it! Get my $ back and buy a non-refurb unit! I've had my G75 and can no ever remember having a Blue screen. There seem to be a lot of these refurb units hitting the retail market lately, I wonder who is doing the refurb on them?
    ROG Enthusiast Array
    Jan 2014
    33
    Since I bought my G75VW I have had a couple bluescreens. The first happened when I installed a new game and for some reason my laptop disliked it. Took an hour to get it back right. Second one was when I updated all the drivers. Never never update all the drivers at one time. Do them one or 2 drivers at a time. That way you can find the conflicting driver and fix it. This kinda sounds like a hardware problem like others have said. But I would not discount driver issues too.
