Results 1 to 4 of 4
    New ROGer Array
    Dec 2013
    2
    Screen dimms when there is dark colors present, lightens when there is light colors
    ASUS G750JX model
    It's very annoying and hurts my eyes, when my screen has darker colors up it dims the display. Then when it has lighter colors up the display brightens.
    Here's an example, I have a black desktop. When I open google chrome to my white home page I can see the start bar light up as the screen gets brighter. Then, when I minimize chrome, there is a brief pause and then the start bar gets dimmer. It's almost like a dynamic contrast, but in bloody reverse.
    TLdr: Dark colors get darker than they should be, bright colors get brighter than they should be.
    It's specific t which program im currently browsing, for example if i have a program in the background that has dark colors but i switch to another program in a small window above it which has light colors, the screen brightens and vice versa.
    It's happening right now with the rog forums since it has black and dark red colors.
    Please help.
    ROG Member Array
    Dec 2013
    16
    Go to NVidia control panel->adjust desktop color settings->use NVidia settings.
    Click apply and restart laptop.
    Post results after trying this.
    New ROGer Array
    Dec 2013
    2
    it worked, thanks man
    ROG Member Array
    Dec 2013
    16
    Problem Solved.That's great news. Enjoy your new ROG laptop.
