Results 1 to 10 of 10
    New ROGer Array
    Dec 2013
    4
    G75VW Laptop Plastic/Material Peeling
    Hello,
    I'm having a peeling problem with my Asus laptop. (The pictures are depicted below.) There doesn't seem to be any kind of glue or chemicals holding them together. Both surfaces are smooth and clean. I have no idea how they are held together. I want to use glue, but I'm not sure which one to use. It seems like it is made to peel off cleanly, but still stick together very tightly. (It is actually hard to peel it off.)
ID:	31507Click image for larger version.
ID:	31508Click image for larger version.
ID:	31509Click image for larger version.
ID:	31510Click image for larger version.
    I still have the 1 year warranty, but I heard many people end up with recurring issues or worsening issues after RMA'ing their laptops. I'm not sure I want to risk introducing new problems with this purely aesthetic problem.
    So, do you guys have further insights into the problem?
    Any suggestions?
    New ROGer Array
    Oct 2012
    13
    2,441
    also you can send to RMA, but i think if that is not affect your use, you don;t need to RMA, but if you think it is not happy for you, sure, you can send to RMA, but, i don;t know it will pay fee or not.
    ROG Guru: Black Belt Array rewben PC Specs
    rewben PC Specs
    Laptop (Model)G55VW-3D
    MotherboardASROCK Z97 EXTREME 6
    ProcessorINTEL 4790K
    Memory (part number)G.SKILL RIPJAWZ 2400MHZ (F3-19200CL10Q-32GBZHD)
    Graphics Card #1ASUS STRIX-GTX980-DC2OC-4GD5
    Graphics Card #2ASUS STRIX-GTX980-DC2OC-4GD5
    MonitorDELL U2713HM
    Storage #1SAMSUNG SM843 480GB X2
    Storage #2WD GREEN 3TB X2
    CPU CoolerSWIFTECH H240-X
    CaseNZXT H440
    Power SupplyTHERMALTAKE TOUGHPOWER XT PLATINUM 1275W
    Keyboard CORSAIR K70 RGB
    Mouse STEELSERIES KINZU V3
    Headset STEELSERIES 9H
    Mouse Pad STEELSERIES QCK+
    Headset/Speakers LOGITECH Z506
    OS WINDOWS 10 PRO AU
    Network RouterASUS RT-AC66U
    Jun 2012
    178
    2,229
    hi @rbtlong, you're the first one who reported this. since your laptop still have warranty left, it's much better to send it to the service center and get it fixed (you should tell them clearly about this: it's an issue of physical laptop case, not system issues). if you're in the US, @cl-Albert can be contacted here for assistance.
    there are some positive changes in asus centers recently. with the help from kind people like @cl-Albert, the probable issues can be further minimized.
    New ROGer Array
    Dec 2013
    4
    wow thanks @rewben this sounds encouraging. i'll try it.
    New ROGer Array
    Dec 2013
    4
    well i sent the person cl-Albert a message immediately after[the post], but since then i have not heard a response. i was hoping for maybe a asus-certified glue or something. i guess i'll have to do my own research on this. anyone with expertise on plastic adhesives on this forum? the two surfaces are smooth . . . and it seems like they are made to be cleanly removable, but bonded very *VERY* tightly.
    rewben PC Specs
    MonitorDELL U2713HM
    CaseNZXT H440
    Jun 2012
    178
    2,229
    @rbtlong, probably he's caught up with other things. for the time being, you can read the rma guide.
  7. #7
    Super Moderator Array
    Jan 2013
    121
    2,274
    @rbtlong, not sure if you saw them, but I sent replies on 12/26 and 12/27, but just resent them today if you want to check again.
    Anyway, to summarize you're probably looking at the 2 options below if you have any interest in sending in the notebook for this.
    1. Contact U.S. ASUS support at http://www.service.asus.com/#!consumer/csn9 and just get it taken care of through them if you like what you hear, but I'm guessing they can't determine warranty status until you send in the notebook or may assume it is out-of-warranty.
    Request the RMA number anyway even if you don't plan to send it to the repair office they set up.
    2. I can help you get it to my office for repair if you're interested, but we have more limited capabilities, so it can slow things down, but I can keep a better eye on it if you expect to run into any problems.
    Also, haven't talked to repair yet to find out if it will be covered under warranty.
    If you arrange it with me, the RMA number you requested in option #1 above can be changed to go to my office if you want to go this route.
    If your notebook is covered under accidental damage for select U.S. and Canadian notebooks and you don't mind using it for this issue, you probably don't even need to worry too much if it will be covered under warranty as long as it will be covered under the accidental damage protection:
    http://www.service.asus.com/#!register-adp/c203q
    Anyway, if you aren't able to receive PMs form me, it's going to be tough to arrange the RMA with me, so hopefully there aren't any problems with this.
  8. #8
    rewben PC Specs
    MonitorDELL U2713HM
    CaseNZXT H440
    Jun 2012
    178
    2,229
    hi @rbtlong, help is coming but please respond
  9. #9
    New ROGer Array
    Dec 2013
    4
    Sorry ca-Albert, not sure why I didn't get the message. I will triple check next time.
    My accidental warranty actually just ran out last month the (December). Is there a way I can still get an RMA # or proceed with this repair? If the cost is not too outrageous, I am willing to pay for it.
    Thanks for the thorough email.
    Quote Originally Posted by cl-Albert View Post
  10. #10
    Jan 2013
    121
    2,274
    No problem, rbtlong and just a reminder that you can reach me at cl-Albert (if you need any help to check and send private messages (PMs) through the forums, let us know).
    Anyway, it's not as easy to arrange the RMA through PMs, so if you're in the U.S. or Canada, can you please contact ASUS support to request the rma number at http://www.service.asus.com/#!consumer/csn9 (be sure to have your notebook serial number ready)?
    You can really make the arrangements yourself with ASUS support, but if you're interested in having me look into it more, send me a PM at cl-Albert with your rma number before you send back the notebook for repair and I'll check into it. Thanks.
Tags for this Thread
