Results 1 to 3 of 3
    ROG Member Array
    Dec 2013
    7
    wifi driver of g750 jw
    I usually have my internet dropped with my g750 jw. The wifi driver of this laptop is broadcom 802.11 ac. I googled a alot and find out that its may be because my driver is not compatible with internet router or hospot or something like that. They say a fix is change BSS mode of the driver but there is no BSS mode but only IBSS. Then i change IBSS mode and it makes no difference. So can anyone who has this internet driver tell me how to set it?
    New ROGer Array
    Oct 2012
    13
    2,441
    what do you mean internet drop? means when you use asus wifi driver can not use internet or driver can not compatible with router or hospot?
    can you tell more?
    ROG Member Array
    Dec 2013
    7
    its like there is still the signal strength but the internet stop working. I cant load a website or while i playing game i get disconnected from the game. It happen every 5 or 10 minutes and last for 10 or 15 seconds sometimes 1 min.
Tags for this Thread
