G750JW color calibration help
smjjames
Hi, I have a new G750JW and I'm having a problem where things have a bluish (or bluish purple) tint and in the minecraft screenshot, the water is purple instead of blue. I attempted to change the hue, which helped slightly, but it still didn't work and the color calibration looks like it should be. I did try to tweak it, but it didn't help.
31633
4 REPLIES 4
smjjames
ANybody? It's not just Minecraft, I was using that as an example.
Pitcher1
try install new driver and setting default in manager, if not help, i think you should send to service cneter to check.
smjjames
I tried that and it didn't work. Though I'll try an older NVIDIA version to see if that fixes anything.
Maxter
Do you have Splendid installed? if so, remove.
