12-28-2013 02:57 PM - last edited on 03-06-2024 10:31 PM by ROGBot
12-28-2013 05:22 PM
12-29-2013 07:17 PM
hmscott wrote:
Are you talking about the end that sticks in the laptop, or the end that comes out of the charger? Mine is solid, the restraining plastic piece isn't moving. The molded plug that plugs in the laptop is solid. Also, it doesn't wiggle in the connector in the laptop. But, it isn't grabby solid - I have kicked it out before and it just slides out - which is a good thing.
If the cable connection coming out of the brick is the problem, you should request Asus send you a replacement and a shipper to send back yours - they should send you a replacement first so you aren't without a charger. You could make a short video or photo's to send Asus showing the problem.
12-29-2013 07:22 PM
Lucas Cardoso wrote:
I mean, the piece of plastic on the charger, the rubbery piece that is thicker than the wire, stuck in the charger.
12-30-2013 04:17 AM
hmscott wrote:
I would get it replaced by Asus, it should be a tight fit to keep out moisture and dust and dirt.
12-30-2013 05:02 AM
I have 2 more laptop charger that do the same thing, then I think its normal. Is your laptop the G750JW ? thanks bro
12-30-2013 06:16 AM
hmscott wrote:
If you think it is normal, why did you open a new thread to ask if it is normal? 🙂
It isn't normal, at least not here in the US, I have only seen damaged adapters with loose fittings. All the other ones are tight and sealed.
12-30-2013 06:16 AM
12-30-2013 06:33 AM
I just saw it. Do u have the G750JW?
12-30-2013 07:07 AM
hmscott wrote:
Currently I have a G750JH, I also had a JW and a JX, one at a time 🙂
