Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 38
    New ROGer Array
    Jan 2014
    4
    G750JH light bleed issues - normal?
    Just bought this. I can clearly see light bleed on edges of screen in desktop mode, using the asus laptop photo background, particularly the right edge. When screen is dark or black, there is a row of alternating bleeds: purple, yellow, purple, yellow. Each is about an inch long, going all the way down the side of the screen. It is not so obvious on direct view but if I move four inches to the left or look at the screen from a higher angle, it it quite pronounced. The left edge does not have this bleeding problem at all. I can squeeze the edge of the bezel and see that it moves, but it never goes away.
    I find this very disappointing considering how much money I paid for this. My wife's $850 acer screen looks way better than this Asus rog.
    I can't imagine this light bleed being normal. I have not read anyone else having this problem though. Should I take it back for a replacement or is this normal for this model? I really don't see it in a regular browsing window because the scroll bar on right edge covers the bleeding areas, but I know it is there.
    Great laptop otherwise, but still nowhere near the quality of my ipad screen for reading text. I got it for games, so not a big deal, but for $2400, I didn't expect an $850 ips acer v7 aspire (1920x1080) to have such a better screen.
    New ROGer Array
    Oct 2012
    13
    2,441
    please send to service center to check it, or you can post photo?
    New ROGer Array
    Jan 2014
    4
    two photos show white screen, but are actually black. that was high iso. would you find this bleed acceptable? Does anyone owning this model have light bleed? for some reason. these photos came out sideways. the bleed is on right edge of screen.
ID:	31927Click image for larger version.
ID:	31928Click image for larger version.
ID:	31929Click image for larger version.
ID:	31930Click image for larger version.
    ROG Enthusiast Array
    Aug 2013
    74
    If look downward into the gap between the screen and the plastic frame I can see the white LEDs in those areas, but I personally have no color bleed like you do on my JX.
    What you showed in the pics is (in my opinion) unacceptable for today's QC on LED displays, both monitors and tvs. I would send it in for replacement if it were me.
    Edit: Also, to compare this screen to an Apple Retina screen isn't really fair. 1080p v. 1440p. Matte v. Glossy. The Retina is a fantastic display, easily the best mass produced screen out there.
    New ROGer Array
    Jan 2014
    4
    I agree this is unacceptable. I will be returning it to future shop tonight and they will mail me a new one, probably next week. . Hopefully, the replacement is good. Since I can't seem to find any complaints about the g750 in regards to backlight bleeding, this is probably a rare dud. Thanks for the input.
    Yes, I am spoiled by my ipad screen!
    New ROGer Array
    Jan 2014
    4
    Got my second 750JH delivered today. Just as bad as the first. Exact same backlight bleed issues on the right side of the screen. At least this time I was able to see the problem immediately on booting it up before even doing any installation or updates. I think that's it for me and Asus. Taking it back to future shop and getting a full refund. I am not going through this a third time. It's a shame too because I really like the laptop. Maybe best buy problems are also future shop problems with this model. I'll have to look at an alternative laptop brand or just build a new PC.
  7. #7
    ROG Guru: Yellow Belt Array
    Dec 2013
    129
    Quote Originally Posted by Shatner\'s hairpiece View Post
    man i have same issue... and its my 3d laptop... i do really like the laptop but this backlight bleed is really annoying... i don't know what to do
  8. #8
    ROG Guru: Platinum Belt Array hmscott PC Specs
    hmscott PC Specs
    Laptop (Model)Asus G750JH-DB71 (legacy)
    MotherboardAsus G750JH Intel HM87
    ProcessorIntel i7-4700HQ XTU Cores 36x/35x/34x/34x Cache 36x -50mV undervolt
    Memory (part number)Hyundai Electronics HMT41GS6AFR8A-PB 1.35v DDR3L-1600MHz
    Graphics Card #1Nvidia 780m Asus GPU Tweak OC 932mhz/6300mhz
    Sound CardRealtek v6.0.1.7469 driver
    MonitorAUO B173HW02 V1 Custom Refresh 85hz
    Storage #1RAID0 2x M.2 SATA Crucial MX200 512GB CT500MX200SSD6
    Storage #2Crucial 512GB 2.5" MX200 CT500MX200SSD1
    Power Supply230w AC Power Adapter 19.5v
    Keyboard Logitech k400 Wireless KB/Trackpad
    Headset Sony MDR-XB500 Wired and Sennheiser RS-220 Wireless TOSLINK
    OS Windows 8.1 + 8 Linux VM's + Windows 10 Technical Preview
    Network RouterAsus RT-AC68U DLINK DIR-655
    Jun 2013
    44
    5,357
    The G750JW/JX have a normally bright display, running it at 90%+ is ok.
    The JH AUO (matte) display puts out too much light at 90%+, the whites bloom at that setting. I run at about 70%, more than bright enough - and running at 70% (or even 50%) might get rid of the most offensive bleed you are seeing.
    Give it a try and let us know how that works for you. It might take a little while to re-adjust to 70%, but it is more than bright enough indoors - sometimes I drop lower.
    I don't reduce the brightness to get rid of bleed, it is just too bright for me, and I normally like the display up around 95-100% - bright.
    There is usually a transition point below which the bleed will drop away. On my TV the bleed starts to show at 53% brightness - the bleed goes away at 52% - one click up and it comes back.
    You might try playing with the brightness/contrast to see if you can find a transition point on your G750 display that cuts out most or all of the bleed.
  9. #9
    Dec 2013
    129
    Quote Originally Posted by hmscott View Post
    So you have this issue too?
    I will try to play with brightness later and let you know.
    Thank you
  10. #10
    hmscott PC Specs
    Jun 2013
    44
    5,357
    Quote Originally Posted by WinterMisha View Post
    Thank you
    In the way that I have a JH that is way too bright all over, yes, but not in the way that light bleed is usually termed, a specific location / area that is brighter than others, usually due to a mechanical attachment 'pinch' / ill fit.
    But knowing how I mitigate light bleed on devices that do have specific bleed areas - by lowering the brightness / LED light, I thought I would mention that trick to you to see if it will help. The JH is already too bright, so there is a lot of fudge room to lower the brightness to kill the bleed while still being bright enough to be normal brightness.
    My TV model is an edge lit LED and I went through 2 before I found one that had the least objectionable localized brightness on the right side, about an inch on the whole right edge. As I said above, 1 step in the brightness setting is the trigger point that changes the bleed from being visible in dark scenes to being not objectionable.
    I hope this works for you, let us know what settings you find are best.
