Results 1 to 5 of 5
    ROG Guru: White Belt Array Bodycount69 PC Specs
    MotherboardASUS ROG STRIX X99 GAMING LGA 2011-v3 Intel X99 Motherboard
    ProcessorIntel Core i7-6900K 20M Broadwell-E 8-Core 3.2 GHz LGA 2011-v3
    Memory (part number)CORSAIR Dominator Platinum 128GB (8 x 16GB) 288-Pin DDR4 SDRAM DDR4 2666 (PC4 21300) Desktop Memory
    Graphics Card #1ASUS GeForce GTX 1080 8GB ROG STRIX OC Edition
    Graphics Card #2ASUS GeForce GTX 1080 8GB ROG STRIX OC Edition
    MonitorAsus ROG PG348Q Black 34
    Storage #1SAMSUNG 850 EVO 2.5" 1TB SATA III
    Storage #2SAMSUNG 850 EVO 2.5" 1TB SATA III
    CPU CoolerCorsair Hydro Series H110i Extreme Performance Water / Liquid CPU Cooler
    CaseCorsair Graphite Series White Steel 780T Full Tower PC Case
    Power SupplyCORSAIR HXi Series HX1200i 1200W 80 PLUS PLATINUM Full Modular Power Supply
    Keyboard Logitech G910 Orion Spark USB Mechanical Gaming Keyboard
    Mouse Logitech G502 Tunable FPS Optical Gaming Mouse
    Headset SteelSeries Siberia 840 wireless gaming headset
    Mouse Pad SteelSeries QcK Heavy Mousepad
    OS Windows 10 64Bit
    Jan 2011
    86
    Upgrading my ASUS G75VW need some help.
    Hi guys I'm looking to install a SSD in my G75VW, now I have installed hundreds off hard drives before but this will be my first SSD drive. I would like to know if I have to change anything in the BIOS ?
    Also if anyone has any tips to help with my install thanks.
    This is the SSD Drive I'm looking at:
    http://www.tigerdirect.ca/applicatio...890&CatId=5298
    ROG Guru: Black Belt Array rewben PC Specs
    rewben PC Specs
    Laptop (Model)G55VW-3D
    MotherboardASROCK Z97 EXTREME 6
    ProcessorINTEL 4790K
    Memory (part number)G.SKILL RIPJAWZ 2400MHZ (F3-19200CL10Q-32GBZHD)
    Graphics Card #1ASUS STRIX-GTX980-DC2OC-4GD5
    Graphics Card #2ASUS STRIX-GTX980-DC2OC-4GD5
    MonitorDELL U2713HM
    Storage #1SAMSUNG SM843 480GB X2
    Storage #2WD GREEN 3TB X2
    CPU CoolerSWIFTECH H240-X
    CaseNZXT H440
    Power SupplyTHERMALTAKE TOUGHPOWER XT PLATINUM 1275W
    Keyboard CORSAIR K70 RGB
    Mouse STEELSERIES KINZU V3
    Headset STEELSERIES 9H
    Mouse Pad STEELSERIES QCK+
    Headset/Speakers LOGITECH Z506
    OS WINDOWS 10 PRO AU
    Network RouterASUS RT-AC66U
    Jun 2012
    178
    2,229
    congratulations you can handle ssd like hdd.
    in the bios, the only thing i can think of is to change the sata operations to ahci. the rest should be simple: if you're running stock w8, just use backtracker to create a recovery usb and proceed with it. if it's a stock w7, you can download the drivers from asus support page and a legal copy of w7 and do a clean install.
    good luck.
    OS Windows 10 64Bit
    Jan 2011
    86
    Thanks Rewben
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    111
    4,186
    Just in case you need a little help with this check out this thread Rewben put together
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    rewben PC Specs
    MonitorDELL U2713HM
    CaseNZXT H440
    Jun 2012
    178
    2,229
    @Clintlgm, thanks a lot! i forgot to put a link to the notes.
