08-09-2010 07:31 PM - last edited on 03-05-2024 06:46 PM by ROGBot
Corsair, a worldwide designer and supplier of high-performance components to the PC gaming hardware market, today announced the Corsair Hydro Series™ H70 ultra-performance CPU cooler. This CPU cooler is designed to provide an extremely efficient cooling solution for CPUs from Intel and AMD.
The Hydro Series H70 CPU cooler is an evolution of the award-winning Hydro Series H50, with several significant upgrades that enable it to deliver even greater cooling performance. These upgrades include a double-thickness (50mm) radiator with higher heat-exchanging capacity and a pump/cold plate unit with increased efficiency. The H70 also features two 120mm speed-switchable cooling fans in a push-pull configuration to provide increased airflow at low noise levels.
08-09-2010 11:11 PM
08-11-2010 10:11 AM
ottoyu34 wrote:
looks like it need some good fans to push air thur that rad.
08-11-2010 11:47 AM
craigbru wrote:
That's what I thought. It does look pretty dense.
08-11-2010 12:02 PM
xeromist wrote:
[vent]Of course if fan manufacturers would just standardize and publish static pressure numbers for fans we wouldn't have this problem! :mad: [/vent]
08-10-2010 08:28 PM
08-10-2010 08:32 PM
08-11-2010 02:14 PM
