Hi all,
I received an I7-4770k for x-mas and am looking to get a motherboard. More specifically I would prefer to get an Asus Motherboard and I would like to use the Maximus VI Extreme, however, I have 2 questions before I make the purchase.
1 Will I have any issues with GPU temps using 2 X GTX680-DC2T-2GD5 on an air cooling system for everything other than the CPU?
2 If the first question is a resounding NO, should I have had heat problems with the same cards installed on my current build?
The reason for these questions is because of the small amount of space between these cards and is explained a little more below.
Awhile back I bought a 2nd GTX680-DC2T-2GD5, installed and began playing some games (MMO's mostly with an occasional FPS). Everything seemed to be good while I tried out a number of games briefly to see how they looked/played with the 2 way sli. Satisfied that everything was up and running properly I got back to my normal gaming, which is when I began noticing the temp on one of the cards was getting rather warm, in the mid to upper 90's C. Not wanting to let either card get above max temps that I found on the internet (98 C max is what I found) I exited the game and let the cards run at idle speed until they cooled down. Since I had been running a single card for a number of months prior to buying the second card and never coming close to temp concerns I decided to remove the second card and test each card running by itself. Both worked fine and the temps were nearly identical during normal gaming. My best guess was that due to the cards being 3 slot cards, which left ~1/4" or less between them, perhaps I wasn't getting enough airflow between the two. My case has 2 - 200mm exhaust fans on the top, 1- 200mm intake fan on the side, 1- 200mm intake fan on the front, 1 - 120mm exhaust fan on the bottom, and 2 - 120mm intake fans in a push/pull set-up for the Corsair H70 CPU cooler. Anyway, I decided to not take any chances running the sli set-up until either I found a solution or upgraded to the 1150 platform. I have spent a number of hours looking for a solution on miscellaneous web-sites forums and can't find anything addressing my specific concern. I have also looked at a number of LGA1150 boards (Asus Z87-WS, Gigabyte G1.Sniper 5, GA-Z87X-OC Force, UD7, and ASRock Z87 Extreme11/ac to name a few) that allow a full expansion slot of space between the cards when installed to allow more airflow between the cards. The problem with the boards I have found is that if I have to go this style of a set-up that most of them aren't Asus boards and the one that is doesn't have ROG stamped on it! Lol.
Thank-you in advance for any help/ideas/suggestions you may have,
Brett
Current build: Upgrades I have already:
I7-2600k I7-4770k
Corsair H70 cpu cooler 2nd Asus GTX680-DC2T-2GD5
Asus P8P67-PRO Rev. B3
16 GB Corsair Vengence @ 1600
Corsair Force GT 240GB SSD
Samsung DVD/CD
WD Black 1.5TB
Thermaltake Toughpower Grand 1050W
Thermaltake Chaser Series Chaser MK-I
Asus VG278HE x 3
Budget: <$500 USD
Main uses of intended build: Gaming
Parts required: Motherboard
Previous build information (list details of parts): See above
Monitor resolution: 1920x1080 - 5760x1080 when available
Storage requirements:
Will you be overclocking: yes, but nothing extreme
Any motherboard requirements: Something that will allow for 4 way gpu in the future
Extra information about desired system:
