Results 1 to 3 of 3
    ROG Member Array
    Dec 2013
    5
    G750JW touchpad scroll zoom hypersensitivity in games, how do I fix?
    I'm finding that in all of my games the zoom (which is changed by scrolling) is being TOO sensitive. Even if I scroll just a tiny bit, it zooms too fast or too much. How do I fix this? While I do have a problem with fine motor control, I didn't have this issue on my old laptop which is also a touchpad. For example, EU4, on my old computer, I don't need to use very fine movements to zoom at a normal speed, but on this one, I have to do very very fine movements in order to scroll normally and that's a problem with me because fine motor control is more difficult for me.
    Also, is there a way to get the touchpad to use single finger scrolling?
    Also, the touchpad spontaneously changes the zoom when I use the single finger to move the cursor around.
    ROG Member Array
    Dec 2013
    5
    Anybody know how I would fix this? would changing the touchpad driver fix this? if so, to what? I REALLY, REALLY want to fix this and for me it's a major problem.
    ROG Guru: Platinum Belt Array hmscott PC Specs
    hmscott PC Specs
    Laptop (Model)Asus G750JH-DB71 (legacy)
    MotherboardAsus G750JH Intel HM87
    ProcessorIntel i7-4700HQ XTU Cores 36x/35x/34x/34x Cache 36x -50mV undervolt
    Memory (part number)Hyundai Electronics HMT41GS6AFR8A-PB 1.35v DDR3L-1600MHz
    Graphics Card #1Nvidia 780m Asus GPU Tweak OC 932mhz/6300mhz
    Sound CardRealtek v6.0.1.7469 driver
    MonitorAUO B173HW02 V1 Custom Refresh 85hz
    Storage #1RAID0 2x M.2 SATA Crucial MX200 512GB CT500MX200SSD6
    Storage #2Crucial 512GB 2.5" MX200 CT500MX200SSD1
    Power Supply230w AC Power Adapter 19.5v
    Keyboard Logitech k400 Wireless KB/Trackpad
    Headset Sony MDR-XB500 Wired and Sennheiser RS-220 Wireless TOSLINK
    OS Windows 8.1 + 8 Linux VM's + Windows 10 Technical Preview
    Network RouterAsus RT-AC68U DLINK DIR-655
    Jun 2013
    44
    5,357
    Quote Originally Posted by smjjames View Post
    The only interface we have to the touchpad is through the Asus Smart Gesture systray settings, and I disable all but the most basic options and enable the external mouse detection to disable the trackpad.
Name:	systray trackpad settings.jpg
Name:	systray trackpad edge gesture settings.jpg
Name:	trackpad disable with external mouse.PNG
    The other settings point is the the Charm Bar => Settings => PC Settings => PC and Devices => Mouse and Trackpad and there I disable the delay. That delay might be getting in the way, making the response jumpy, which is what you symptoms indicate.
    Asus posted a new touchpad driver to the JW area, and also available at the Touchpad support download area:
    http://support.asus.com/download.asp...ZFxIpLeKBoVabd
Name:	touchpad driver g750jw download area.PNG
    http://support.asus.com/Download.asp...Touchpad&os=30
Name:	Asus touchpad driver download area.jpg
    You could also try the sensitivity settings for the Mouse control panel:
Name:	mouse sensitivity settings.jpg
    I also disable the annoying expand window frame when I move a window to an edge.
Name:	prevent windowsw from automatically....jpg
    You could also try finding the Elantech controls, which adds a configuration tab to the Mouse Settings:
    http://www.emc.com.tw/eng/st_tpn_sp.asp
    They say to look to your manufacturer for the download, but Asus substitutes their own controls instead of passing on the driver directly from Elantech.
    You might try asking Elantech how to solve that particular issue, if you don't get it fixed with the Windows/Asus tools...
