Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 28
  1. #11
    Dec 2011
    358
    25,742
    Cheers for the update will keep checking back to see how it goes after a couple of days
  2. #12
    ROG Member Array
    Jan 2014
    All the drives you said installed, I still have this one... I'd like to have everything installed, but I think this was the one that was giving me the headaches.
  3. #13
    Dec 2011
    358
    25,742
    If you want to have driver for ACPI\PNP0A0A setup while not installing Asus AI Suite - it involves using Asus driver CD and dreaded Asus com driver will be installed as a part of this process.
    Here is what you need to do: on your Asus DVD that came with your board navigate to \Bin\AMDA00\x64 (or x32 for 32 bit OS).
    Run AsusSetup and after it completes that device will now be under "System Devices". It is called "AMDA00 Interface".
    If you go to to "Driver file details" you will see that Asus com service is listed as a part of the files from which this driver package consists.
    This has worked each time in the past. You can simply ignore this too by the way.
  4. #14
    ROG Member Array
    Jan 2014
    Pretty sure I used this to install it the last time.
    ASUS_AMDA00_ACPI for Windows 7 32/64bit & Windows 8 32/64bit & Windows 8.1 32/64bit.
  5. #15
    Dec 2011
    358
    25,742
    Then there is nothing more I can do I am sorry.
  6. #16
    ROG Member Array
    Jan 2014
    But what you think its the best way?
    And thanks for all the help and quick replies!
  7. #17
    Dec 2011
    358
    25,742
    I have never personally had this, but based on what I have seen you can ignore it with no worries. I have asked someone else who has dealt with this to respond when next he is online.
    I would not be fussed about it, I would simply let it be.
  8. #18
    ROG Member Array
    Jan 2014
    Just saying because if its supposed to work it can be hardware malfunction and this hardware is brand new!
  9. #19
    Dec 2011
    358
    25,742
    Nope it is driver related not hardware have seen this a couple of times now, that is why I know it is not a big deal. Just wait for the other lad to come on line.
  10. #20
    untouched Array Praz's Avatar
    Apr 2011
    137
    4,037
    The AMDA00 Interface driver is needed for some parts of AISuite as well as the Boot To BIOS utility. If you are not using either you do not need to install the driver. If you wish to install this driver it should be in Bin folder of the motherboard driver disk.
