Results 1 to 2 of 2
    New ROGer Array
    Jan 2014
    1
    G750JH GPU Fan Noise
    I bought my G750JH a month ago and wasn't sure if this is normal or not...
    The cooling works very well, the temps don't exceed 70°C under load, the only thing that's bothers me is the sound of the GPU fan under high load (recent game, all settings high). It's a high frequency-rattling sound that's a bit nerving even with headphones on. The CPU fan for example is under high load (benchmark) much quieter. I recorded it out of 30 cm distance and out of 3 cm distance placed centered between the two fans: https://www.dropbox.com/sh/ng03ne1pbtle4q7/jBhOK1mrGV (works fine with vlc player). If you could take a quick listen and feed back...TY!
    New ROGer Array
    Sep 2013
    3
    well in my opinion you can see that asus is not very good in quality but in advertisement only.
    thats my opinion.
    cause i have the same problem
    Gingineer
    ASUS G750JH
    CPU: Intel Quad Core I7-4700HQ@ 3.4GHz
    GPU: Nvidia GeForce GTX 780M (4GB)
    RAM: 32GB
    HARDDRIVE: 1TB + 1TB
    OS: Windows 8
