Results 1 to 4 of 4
    ROG Member Array
    Sep 2013
    11
    Help with broken arrow key & a character question...
    Hi, I have a G75VX & recently had an arrow key return spring? break or collapse because of playing a game in which I utilize the arrow keys as joystick support isn't available for that game as of yet.. is repairing this something that can be done by me? The key still works just it doesn't pop back up like all the other keys on the keyboard...
    Also, does anyone know how to make the symbol for the british pound £ work with a single keystroke as opposed to having to do a shift+alt+0163 ? (& no, copy & paste is not an option in this circumstance..) I have looked at my character map as well as searched online & I am stumped.. something about changing keyboard to UK maybe? I only need to be able to do this one single time via a single keystroke.. shift + a single key is fine I think too..
    Thanks to anyone who can help me with these 2 questions/problems!
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,137
    Replacement keys I replaced my J key they send you all three parts. Instructions on their web page. Easy to do
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Member Array
    Sep 2013
    11
    Quote Originally Posted by Clintlgm View Post
    Thanks Clint !
    Now for the stupid british pound symbol.. something which I thought would be an easy task lol!
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,137
    Sounds like your either going to have to install a British style keyboard software or use an external British KB or perhaps write a Macro, maybe Goggle for some keyboard mods? Seem to me a macro could be written that when Shift + 4 would produce the British pound sign. instead of the $ sign?
    Check out this thread http://superuser.com/questions/13324...ndows-globally. I didn't read it all but it sounds like what your looking for.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
