Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    ROG Enthusiast Array ChikNoods PC Specs
    ChikNoods PC Specs
    Laptop (Model)G74
    MotherboardMaximus HERO VII
    Processori7-4790K
    Memory (part number)HyperX 8GB
    Graphics Card #1STRIX 970
    MonitorVG248QE
    Storage #1Samsung 850 EVO 250GB
    CPU CoolerH100i
    Case750D
    Power SupplyCorsair 760
    Keyboard Leopold FC900R LED
    Mouse Deathadder
    Headset Kraken Pro
    OS Windows 7x64
    Sep 2012
    17
    39
    Quote Originally Posted by DoGood View Post
    It is possible to have the power options set to high performance and have the minimum processor state below 100%. I did it manually, but I suppose software could have done automatically.
    Go to Power Options > "Change plan settings" on the high performance row > Change advanced power settings > Processor power management > minimum processor state. Make sure that is set to 100% for plugged in.
    Was it lower in your case?
    all are set to 100% in processor power. I ran the test again and re-upped and its reporting 2593.8 MHz now -- not sure what happened
    yes lower before. most of the G74sx report 798
  2. #12
    ROG Guru: White Belt Array Ambidexter's Avatar
    Sep 2013
    79
    Does it affect score?
    Whether or not RB2.1 reports the CPU freq correct or not is a bit odd. But, what I wonder is does it affect the score? Do the same times and openCL score give us the same overall score?
    With Intel Extreme Tuning Utility after benchmarks run, the score changes with the same test time, if the voltage is lower or the CPU is higher or using some other logic.
    Actually, a post on this thread seems to get close to what IETU does. IETU's "benchmark" is just a 30 second or so test with 4 or 5 up/down cpu tests and a score that is returned which considers the max CPU, voltage, etc. So it's possible RB could do an initial "what's your CPU's speed?" test then use that in reporting results. I'd prefer this rather than having RB disable any max/min CPU I've selected in my power plan.
    Thanks again for a great program!
    Cheers,
    -Ambi
    MB: Maximus VIII Hero
    CPU:Intel i7-6700K OC @ 4.7 GHz
    Mem: 32GB Corsair Vengeance LPX @ 3600 MHz
    Vid: EVGA GTX980 Ti SC@ 1530MHz
    SSD:RAID1&0 Samsung 256G 840 Pro
    HDD: RAID1 6TB Ultrastar 7K6000
    PSU: Corsair AX1200i
    Case:Corsair 600T, mod for roof rad
    Custom Loop:
    Block:EK Supremacy Clean CSQ, Copper
    Rads:AlphaCool ST30 360 & 120
    Fans: 4 X Enermax CLUSTER Advance, Bitfenix Spectre Pro 200mm, KingWin DB122
    Pumps:2 X MCP 35x in series
    Tubing:Tygon 2475 1/2" ID X 3/4" OD
