G750JH Max GPU (gtx780m) temperature advice, please.
Olomez
Hi!
i've just bought the g750jh and while playing some games on ultra settings I got around 76-78ºC, once up to 80ºC. Should I be worried about it? If not, what is the maximum temperature I could get?
I'm not an expert on this, so any help would be MORE than helpful 🙂
Thank you in advance!
5 REPLIES 5
angrylemon
That temperature is fine, if it reaches 85+ consistently then you should be worried.
Olomez
Thank you! 🙂
Also, would a notebook cooler help to lower a couple of degrees?
angrylemon
Been using a cooler master cooling pad myself for awhile and it does help.
Sava_Ford
My temp while playing BF4 on ultra is 74 - 76, in other games can be 64/78. Everything about 80 and little more is ok. Don't worry bro. Maybe cooling pad can help, but nothing specialy. Maybe 1-2 degrees 😉
sevymar
