Rampage III Extreme + some secret sauce settings = better coldbug response.
Retired
Not applicable
Recently In some testing an interesting find was made on Rampage III Extreme, not only was the board able to tune away -40C worth of cold bug but it was also able to recover from coldbug on 3 diff boards using 3 different bios versions on 3 different chips.
When there is more data this info may be passed on but atm we need more data as it may not work 100% of the time
Here is a video of a first time girl ocer recovering from coldbug while in windows and continuing to bench without a reboot.
9 REPLIES 9
Retired
Not applicable
Kaboom hit 6 GHZ here but she eventually got up to 6.4! for learning from the ground up on the ROG board line up in 1 weekend, this was epic! Good job team!
Retired
Not applicable
Great to see ASUS supporting this board like that! Looking forward to more info on this! 🙂
Retired
Not applicable
so no info on what you are doing lol ?
Retired
Not applicable
not yet splave, want to avoid the BS the settings don't work for me posts....also want to test more chips and or various batches to see if it's something that can be added to bios or maybe "batch dependant"
To put simply one chip which I believe to be "damaged" it did not work at all on, aka coldbug was the same.....need to determine if it's due to being damaged or some other anomally.
TBH however there is no secret setting in my bios if you want to spend 3 hours like i did on ln2 just fooling with settings you can probably figure this out on your own......and share it with competing teams who didn't spend the time and energy. Not like this is a COLD bug modded bios situation.
DarthBeavis
the secret is the circular mouse motions
I thought it was u sneaking all the Redbull in my POT??????
Here is what I was doing in the BIOS when I was able to pull out of coldbug in windows and complete the benchmark
My QPI was: 1.35v never went past 1.4v
My PLL is also set to 1.55V
My PCIE clk is: 100Mhz
My DRAM, UCLK, QPI are all on lowest dividers, QPI is on SLOW MODE
my IOH and ICH voltages are set to AUTO
QPI PWM: 1.33x
IOH PWM: 1.33x
DRAM PWM 1.33x
DRAM Timings: all AUTO
for CPU config, I disable all features but Prefetcher and cachine
I have LN2 Mode jumper disabled
the CB pullout is different for every chip, you have to tune your chip on LN2 for best clock speed and tweak every voltage and divider and test CB, pushing to see what settings improve your CB this can usually be done in an hour or 2
Some chips would CB at -140 and after tuning for an hour i could get CB up to -175ish
one of my chips CB at -150ish and I could tune it for hours till i got to -190ish
kinda a time consuming way to over clock but i dont yet see any data at this point to show a reliable trend in bios settings that can be universally applied to CPUs
If i pickup a new chip i have to spend a lot of time failing on applied settings before i see net results in overcoming the cold bug
could it be that some areas of the chip are running warmer than others? while we are able to get other areas colder? (not like ramping a high QPI or Core Voltage)
When i get my hardware back from FedEx and have LN2 to test BIOS settings i will be posting my results on the forums
__________________
intressting, how many chips did you test with this setting? are them all same batch ?
i'll try it soon
Retired
Not applicable
7 chips hiwa, one it did not work on but note I believe this chip to be damaged, chips ranged from retail to ES various batches.
Yeah it was crazy, we pulled out of that cold bug quite a bit. As soon as my mouse froze we grabbed the torch, and it took about.. a 15-20C drop in temperature to bring it out of the cold bug, and the system went on running as if nothing had happened. The only voltages I could remember being remotely high was my CPU which I was running around 1.8V. Or maybe... the board is MAGIC! xD
