Greetings Modders, and ROG's,
I have a nVidia black and lime green case made by cooler master. It looks just like this currently:
As I have mentioned in another thread I am going to build a new case, but before I do, I thought Id cut my teeth on something a bit easier and mod this case a little.. simple stuff I am sure many of you would laugh at. Like new paint, some lights and other simple stuff like that.
Why is this titled Geforce Lan inspired, if you look at the banner posted here for the event, it is purple and green. So I am going to attempt to make my case refelct that image with purple and green paint and lights.
LIGHTS:
I was thinking of using these:
http://www.xoxide.com/lamptron-spectral12ccflbar-green.htmlhttp://www.xoxide.com/lamptron-spectral12ccflbar-uv.htmlOr maybe trying these;
http://www.xoxide.com/flexiglow-pcxtremeneon-standardkitultraviolet.htmlhttp://www.xoxide.com/flexiglow-pcxtremeneon-standardkitgreen.htmlThe case came with green LED fans.. so that is covered, but I may switch them out for these;
http://www.xoxide.com/enermax-t-b--vegas-trio-120mm.htmlOr maybe these;
http://www.xoxide.com/gelid-gamer-80mmfan-green.htmlhttp://www.xoxide.com/quadpurled80.htmlAs for the paint.. I have;
OUTSIDE:
http://www.rustoleum.com/CBGProduct.asp?pid=463INSIDE:
http://www.amazon.com/Krylon-2305-X-Metals-purple/dp/B001OKOGLOSo there ya have it, what do you all think?
Since I have a new system due here soon, I will be giving this one to my youngest son.
WINNER Of: iBUYPOWER / ASUS - GAMER PALADIN Z68
CPU - 2nd Generation Intel® Core™ i7-2600K Processor
MoBo - Maximus IV Extreme-Z
ODD - BLU-RAY Reader Combo Drive
PSU - 850W Extreme Gaming Series Power Supply
VGA - ASUS GTX 570 DirectCU II (1 GB)
Memory - 8GB DDR3-1600 Memory – Corsair Vengeance
Audio - ASUS Xonar DX
Networking - Killer 2100 Gaming Network Card
Hard Drive - 60GB SSD SATA III 6Gb/s – Single Drive
( I WAS A G4MER, WHEN G4MING WAS UNCOOL )
