Results 1 to 4 of 4
    wbangert
    Guest
    G74SX HARD DRIVE CABLE
    I purchased a G74SX. I am adding a second HD. I am looking at what appears to be a micro cable for connecting the hd. How to and where does this cable go?
    ROG Guru: Orange Belt Array
    Sep 2011
    22
    368
    if it's liek the others there is no cable, it plugs into a socket on the board.
    ROG Guru: Orange Belt Array Boosted_R's Avatar
    Aug 2011
    12
    279
    GL702VSK / GTX 1070 / M.2 960 EVO
    HTPC MINI-ITX / FRACTAL CORE 500 / GIGABYTE GA-AB350N / GTX 1050 Ti Windforce OC 4G / RYZEN 5 1600 3.9GHz / M.2 960 EVO / G.SKILL Ripjaws V Series 3200MHz
    OLD
    ASUS G74SX-XC1 / INTEL 7260 AC / Samsung 850 PRO / TUNIQ TX-4 / BIOS 203 / 335.23
    New ROGer Array
    Jun 2012
    2
    where did you buy it from? it should have come with instructions, if you google the model number you should be able to find the pdf guide, or just go to youtube type in the model number and see what comes up
    Watching movies on 1channel infomation
Similar Threads
  1. Get your G73 Hard Drive Caddy here!
    By Mason@ASUS in forum G Series Gaming Notebooks
    Last Post: 03-14-2012, 04:58 PM
  2. hard drive partitions
    By moqel in forum G Series Gaming Notebooks
    Last Post: 11-11-2011, 11:58 AM
  3. G74SX-A1 Second Hard Drive Install (SSD)
    By Rack0 in forum G Series Gaming Notebooks
    Last Post: 08-24-2011, 03:00 AM
  4. I'm having a problem cloning my hard drive
    By Joester2007 in forum G Series Gaming Notebooks
    Last Post: 07-31-2011, 06:16 AM
  5. 2nd hard drive install
    By ericforman in forum G Series Gaming Notebooks
    Last Post: 06-17-2011, 07:16 PM
