02-20-2014 06:03 AM - last edited on 03-05-2024 11:38 PM by ROGBot
02-20-2014 05:02 PM
KPECTOK wrote:
So, i'm about to by a new PC and before i will i would to know the Pros and Cons on the build or the parts so if you guys have something to say, please do.
Case: Corsair Graphite Series 600T
MB: ASUS Maximus VI Formula
CPU: Intel i7 4770k
CPU Cooler: H100i
RAM: Corsair Vengeance 8GB 1866 CL9
GPU: ASUS GTX 780 Ti DCU2OC
PSU: AX860i
HDD: WD Black 1TB
SSD: Asus Raidr Express 240GB
OD: ASUS BW-16D1HT
The reason i chose the AX860i is because i will do an SLI with the same kind of GPU.
I will not do an OC to the GPU/CPU (at least right away, maybe in the future)
I will mostly do some gaming and a bit of video editing but not the professional kind. (i think the RAM should do it)
If you are having some kind of problems with any of those components please tell me.
Thanks, KPECTOK.
02-20-2014 05:25 PM
02-20-2014 06:36 PM
Antronman wrote:
I wouldn't recommend the graphite 600Ts because they have poor expansion and poorly positioned fan mounts. If the Hard Drive is the WD Black 2 1TB, that is an SSD+HDD drive. Other than that my only complaint would be that the GPU is Nvidia, because I'm more of a Radeon guy.
02-20-2014 07:24 PM
Zeruel wrote:
Get a 500GB Samsung 840 Evo instead of the ASUS Raidr. It costs less, has twice as much storage(Still an SSD, Fast enough!).
Also if you want to wait, dont get the Corsair Graphite 600T it is a bit out dated and replace by the Graphite 760T WHICH LOOKS BEAUTIFUL!!
It releases on the 17th of next month so I recommend you wait for it!
Also I recommend getting Corsair Vengeance Pro Red Ram since it would look much better in the formula board.
Hope it goes well!
02-21-2014 01:08 AM
Hope it goes well!
02-21-2014 01:12 AM
Hope it goes well!
02-21-2014 12:54 AM
02-21-2014 06:49 AM
02-21-2014 08:12 AM
