03-08-2014 02:05 AM - last edited on 03-05-2024 11:33 PM by ROGBot
03-08-2014 04:03 AM
03-08-2014 05:52 AM
03-08-2014 06:17 AM
DasDinkleberg wrote:
> ram : corsair vengeance pro 16GB 1866mhz or gskillz trident x 16 gb 2400mhz (both are 2x8gb and still not decided yet)
03-09-2014 05:58 AM
Arne Saknussemm wrote:
Looks like you did your homework OK! That looks like a great build and will be a gaming beast.
No real advice....just take your time putting it together....maybe get some thermal paste? Prolimatech PK-1 for example will be better than the paste the H100i comes with...too much paste on H100i when it is fresh out of box...
Start by testing each GPU separately and find out which is the stronger card if you are OCing. Put the stronger card as first card since it does more work. OC from the BIOS better than with presets etc.
Happy building! 😄
Zka17 wrote:
Indeed, a good selection of the components!
Only one thing... what are the timings of those Vengeance Pro and TridentX kits you're looking at? You know, frequency is not all... for efficiency timings are equally important...
Chino wrote:
The TridentX kit is the perfect match for the Maximus VI Hero. It's an awesome high performance kit that doesn't break your pockets.
03-09-2014 06:47 AM
03-09-2014 07:23 AM
03-09-2014 07:31 AM
03-09-2014 09:01 AM
Praz wrote:
Hello
Comparing apples to apples the 1866MHz Trident X with better timings is only $10.00 more that the VENGEANCE PRO. As Chino wrote above you can't go wrong with Trident X.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231623
03-09-2014 09:09 AM
Praz wrote:
Hello
