Results 1 to 4 of 4
    New ROGer Array
    Mar 2014
    1
    Minecraft running at 6-20 on asus r46vw
    So I recently updated my nvidia drivers and since that my minecraft have been running super slow.Before i would get about 230-250 fps but now im lucky if i get 30fps.What is going on?How can i fix this?I have already updated Java to.
    BTW:I can play other games fine (THIEF2014:19-30 on high settings;SouthPark The Stick of Truth:27 fps)
    PC SPECTS:
    RAM:8gb
    GRAPHICS CARD:Nvidia GTX660m
    PROCCESOR:Intel Core i7-3630QM,2.4GHz
    OS:Windows 8
    HDD:128GB + 750GB
    ROG Guru: Brown Belt Array abvolt's Avatar
    Aug 2013
    41
    1,131
    A lot of people are having issues with 334.89 maybe you should roll back to 331.82 see if that works. It's the best so far for me at least..
    Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
    NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
    Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
    Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
    ROG Member Array
    Mar 2014
    11
    well...there might be a lot of redclocks or or anythign that would lag you out, also check your fps settings...and set them to maximum or no limit,
    if this isn't it it must be your drivers.
    New ROGer Array
    May 2020
    4
    Wow, this is really strange, man. Minecraft is not greedy on resourses and is pretty well optimized, so there should be no problems at all. Even computers with much worse specs can run this game. I think that the problem is software related. There must be some bad drivers or system errors. I would suggest reinstalling drivers, directx, vcredist and all stuff like this. I have recently read some articles about minecraft on https://www.ethershock.net/ and wanted to play this game too. I had a pretty low fps, but this manipulations have helped me to get rid of them. I think that it should help you too.
Tags for this Thread
